Will these 37" tires fit on my 10" lifted 2WD 1500
Old Jan 8, 2011 | 06:23 PM
meltorres's Avatar
meltorres
Default Will these 37" tires fit on my 10" lifted 2WD 1500
I have a 2006 Dodge 1500 2WD its got a 7" CST suspension lift and also a 3" performance accessories body lift. I currently am able to clear my 35x12.5R20 toyo open country m/t's, but I am planning on purchasing 37" tires within the week. Will I run into any problems with rubbing cause the new tires will be 37x13.5R20 and I currently have 20" KMC rockstars that are 20x8.5 in specs and have about 5" backspacing.
If anyone could help me out I would gladly appreciate it
Old Jan 8, 2011 | 06:45 PM
Suckingas03's Avatar
Suckingas03
Not sure because I am not an expert on tires or rims, but your rim might not be wide enough for your tire. But someone on here will know for sure.
Old Jan 8, 2011 | 08:59 PM
ram man17's Avatar
ram man17
You will be able to clear 37s for sure. Might wanna upgrade your gears. Problem is your rim width and tire width. When I bought my rockstars they said 33x12.50 was the widest I should go. 13.50s is too wide and isnt safe
Old Jan 9, 2011 | 06:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said, 37s will clear with 10" of lift. No worries there.
Old Jan 9, 2011 | 07:48 PM
Matt99's Avatar
Matt99
I've got about 6in of lift and the same tires and no problems. Width and height. I think you will be alright
Old Jan 9, 2011 | 08:18 PM
ram_bo06's Avatar
ram_bo06
pics?
Old Jan 9, 2011 | 09:58 PM
ram man17's Avatar
ram man17
hes talking about the 37s hes gonna put on. 20x8.5s is not wide enough for 37x13.50?
Old Jan 9, 2011 | 11:40 PM
oefootball_70's Avatar
oefootball_70
height wise, yes you can clear the tires.
But idk about the wheel and tire width. I am not experienced with all of that enough to tell you yes or no...
Sorry.
Old Jan 9, 2011 | 11:48 PM
Matt99's Avatar
Matt99
No way you can fit a 13.5 on an 8.5" rim
Old Jan 9, 2011 | 11:54 PM
oefootball_70
I fit a 12.5 on a 8 inch rim.... so IDK. Call your local tire shop and ask.
