Warm-up Idle Article
Old Jan 10, 2011 | 02:53 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by davidonmars
Also I dont know if its normal but when its cold like below zero my truck takes a while to engage overdrive, not sure if its cause the tranny has to come up to temp?
There's a filter on the return side of the trans cooler that may have a bad checkvalve that is allowing the fluid to drainback into the pan from the torque converter. The newer design filters without the AB suffix at the end of the part number prevent this. The only negative effect of the older designed filters was they took longer to engage. No other bad effects.
Old Jan 10, 2011 | 03:07 PM
harby's Avatar
harby
[quote=davidonmars;2377123]Windchill doesnt affect vehicles though!! [quote]
Can you explain how you come to this conclusion? If there is wind at low temps there is windchill...... so surely a car can be chilled further byt he wind?
Old Jan 10, 2011 | 04:37 PM
freestyledude's Avatar
freestyledude
Windchill is the effect wind blowing by has on human skin, the moisture evaporates around the skin creating a cooling effect. However, it does seem that vehicles kept out of the wind, even without heat, start better.
When it's more than 10 degrees below freezing outside I let my truck warm up for 10-15 mins, enough to make the coolant gauge go up a bit. I put it in neutral as well to help the transmission warm up a bit. Plugging in a block heater helps for easier starts, and oil will circulate through the motor faster off startup
Old Jan 10, 2011 | 06:19 PM
MikeHTally's Avatar
MikeHTally
Machines don't feel wind chill. The transmission is designed to stay out of O/D until the temps have come up. Warm-up for the vehicle's sake is a waste. It'll warm faster working than idling. If I let mine idle for ten minutes, it's barely off the "cold" peg. If I drive it those ten minutes (1/2 way to work), it's well warmed up and giving me nice warm air in the cab.
Old Jan 10, 2011 | 07:12 PM
slimvela's Avatar
slimvela
Since the article is speaking of winter I'll stick with that.
As Dirty stated, I warm up the fluids and start the vehicle in motion when I see the temp begin to rise. Besides, I don't like to go from a warm comfortable house into a rolling ice box either. ;-)
Old Jan 10, 2011 | 08:17 PM
akguy09's Avatar
akguy09
Default winter warm up
I live in Alaska and when the ambient temperature is -50 you must let it warm up. There is no way you could just start it and go. Belts must have some time to warm up and fluids needs some temperature before you can just start "working" the engine too much.
Old Jan 11, 2011 | 09:01 AM
Blacksport's Avatar
Blacksport
Windchill doesnt affect vehicles though!! Although I do warm my truck up for like 10 minutes... If i drive it like 30 seconds after startup on a day where its freezing I can literally watch my fuel gauge drop, and I freeze my *** off!! Also I dont know if its normal but when its cold like below zero my truck takes a while to engage overdrive, not sure if its cause the tranny has to come up to temp?
It sure does if you are parked into the wind, which my truck always is the way my crescent is!!
Old Jan 11, 2011 | 11:21 AM
Marx's Avatar
Marx
i let my truck warm up so i can see thou the windshield lol and so i don't freeze my *** off, I can't see how idling can hut an engine, that part makes me laugh
we should run this by the guys way up in northern Canada that leave there diesels running 24/7 because if they turn them off they will never start again lol
Old Jan 11, 2011 | 11:32 AM
Marx's Avatar
Marx
just found this online lol
Eight Facts About Warming Up Your Car in Winter.
1] It’s harder to drive a vehicle when your teeth are chattering.
2] Blower fans create wind chills
3] If your windows aren’t defrosted you can’t see the road or pedestrians
4] When your windows freeze up and you can’t get them down you create a hazard getting toll tickets to enter the highways
5]If it’s snowing your window wipers will instantly freeze ice on a window that is not properly defrosted.
6]When your whole body is shaking from the cold your attention to the act of driving is reduced.
7]Ice encrusted windshield wipers are less likely to work.
8] It’s cold out ~ Warm up that car - unless you drive an old VW bug ~ The heater won’t work anyways. Good luck.
Old Jan 11, 2011 | 04:26 PM
bgbluram2's Avatar
bgbluram2
I like everyone's input on this.. I know there are extreme conditions such as those up in the big country north of the U.S., but I think that this article was probably written by a Prius driving hippie. Sure, the vehicle may run in closed loop for a while until it reaches an operating temperature, but that goes for any computer controlled vehicle any time of the year.
I'm glad it has sparked some humor/interest on this forum, because I think some of this information can be helpful to some. I use my remote start just about every day in the winter, and I wouldn't have it any other way.
