p302
Old Jan 22, 2011 | 07:05 PM
vegastom69's Avatar
vegastom69
Unhappy p302
hello guys pulling my hair out on this one have 2003 1500 with the little 4.7 changed plugs and coil for number 2 reset engine light light stayed off for a week now back on anyone else run into this ? if so what did you do to fix this have only 39000 miles thanks
Old Jan 26, 2011 | 10:25 PM
vegastom69's Avatar
vegastom69
come on guys 84 views and no body has a answer ? need to get thing to pass a smog test any help would be nice
Old Jan 27, 2011 | 07:48 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
So you got misfire codes right? You changed the plugs and you swapped the #2 coil with the coil from another cylinder right? Check all the electrical connectors and grounds. Is there any play in the valvetrain assembly?
Old Jan 27, 2011 | 09:24 PM
vegastom69's Avatar
vegastom69
yes you are right but repaced the coil pack with a new one and cant find any play in the valve train 125 compresion in all cylinders,only 40,000 miles ,seam to think its fuel related , anybody can tell me how to check the fuel press over night and what it should be thanks
Old Jan 27, 2011 | 09:46 PM
Josh E's Avatar
Josh E
I just had my Impala SS throw a p307 which is a number 7 missfire and it ended up being a weak injector. I replaced, plugs,wires, and the coil and STILL ended up replacing the injector. Good luck
Old Jan 28, 2011 | 07:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check this link out for some help maybe
https://dodgeforum.com/forum/3rd-gen...m-alldata.html
Old Jan 28, 2011 | 05:17 PM
dodgeboy1979's Avatar
dodgeboy1979
was the code the reason for changing the plugs? I would try a different plug in that cylinder.
