03 ram 1500 5.7 differential question
Old Jan 24, 2011 | 09:01 PM
AJMAG's Avatar
AJMAG
Default 03 ram 1500 5.7 differential question
need to know what kind of diff my 2003 ram 1500 5.7 quad cab has??
anyone?
thanks
Old Jan 24, 2011 | 10:04 PM
03MopaRamman's Avatar
03MopaRamman
On an 03 Model, There is Both a Metal Tag on the Rear Diff and a Sticker in the GloveBox that tells you what Type of Diff and the Ratio you have. Not sure if the front C205 Diff has one as I did remove mine when I first changed the Fluids and stuck-em in my tool box! hope this Helps.
Old Jan 25, 2011 | 01:30 AM
AJMAG's Avatar
AJMAG
i think they are the chrystler 9.25 diffs but just double checkin..ill look in the glove box tomorrow, thank you
Old Jan 25, 2011 | 05:40 AM
abarmby's Avatar
abarmby
9.25" rear and 8" front.
Al.
Old Jan 25, 2011 | 06:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Al.
x2......
Thats gear size. Whether is it open diff or LSD diff you will need to check that tag or look in glove box on the door or get a build sheet that lists everything that came with your truck
