Personal Opinions Lift Kits Or Leveling Kits
Old Feb 9, 2011 | 12:22 PM
Rolling_Thunder10's Avatar
Rolling_Thunder10
Default Personal Opinions Lift Kits Or Leveling Kits
I have been kicking around the idea of lifting my 2005 1500...I have been getting some prices and trying to do as much reading on here as possible.
I have not been able to figure out which is better....
So I have narrowed it down to a few choices...Please Advise
Have you guys had any major problems with either???
1. Skyjacker 6'' Suspension Lift W/ Add-A-Leafs
2. 5'' Zone Offraod Suspension Lift W/ Rear Blocks
3. 2" Zone Offroad Leveling Kits W/ Rear Blocks
Old Feb 9, 2011 | 12:45 PM
Geezir's Avatar
Geezir
It's apples and oranges man.
All depends what your goal for your truck is. If you want it big then the obvious option is a lift kit. If you just want your truck to have a level stance then the obvious answer is a levelling kit.
For me, my truck is a work truck. Lifting it while would look good would take away from the functionality of the truck so I just went with a levelling kit.
Old Feb 9, 2011 | 02:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im assuming you have a 4wd? Also check out Rough Country and CST lifts.
Old Feb 9, 2011 | 08:06 PM
Rolling_Thunder10
Yes, I have a 4X4 ... And this is more for looks than anything else... I do minor four wheeling...mostly during hunting season...But nothing serious...
I want the best equipment ... I don't want to worry about breaking CV's or Ball joints or anything else for that matter.
Old Feb 9, 2011 | 08:20 PM
blkramon20s's Avatar
blkramon20s
Its all in what you want i put a 2.5 inch leveling kit on my 07 and hated it from day one but i was one of the un lucky guys who got the random 4wd shake after install so i just ordered a 6" rough country and love it.....
Old Feb 9, 2011 | 10:06 PM
drewactual's Avatar
drewactual
I just dumped my level kit for a RC lift.. night and day..
with the level kit I lost full turn due to rubbing, and the steering knuckles were colliding with what the hell ever you call those things they were hitting.. (yeah, real descriptive- sorry).. I wouldn't dare take a substantial compression of the suspension while turning.. It was bad.. but it sure looked good..
Put the lift on a few weeks ago, and the truck drives like stock again.. Full turns, full articulation of the suspension, and handles much better than the leveling kit did..
I also put skyjacker softride +3" leaves under the back, and with 2" blocks under them.. THAT, really helped handling- as well as gives me a little more confidence hauling/towing than i had before..
I have just shy of $2k total in the lift..
Old Feb 10, 2011 | 09:06 AM
Rolling_Thunder10
Have you guys had any issues, parts break, anythings along those lines with the lift kits?
Old Feb 10, 2011 | 10:36 AM
HammerZ71's Avatar
HammerZ71
Don't know anybody with the Zone on a Ram, but they have a good rep among the Jeep crowd. I've looked at the 5" kit and they appear to be very good for the money. Although I'd prefer a full sub-frame as opposed to cross-members, they do have the drop brackets which allows the CVs to operate at or near stock angles. Appears to be a solid, bargain-priced kit. I'd pick it over most of the kits I've seen in it's price range.
The Skyjacker is obviously a higher end kit, but twice the money. For your stated uses, I think the Zone is adequate, but if $ is not an issue, I'd go for the Skyjacker.
As far as the level kit goes, they are just your basic keys, but in this case with the rear blocks to keep the "rake" look. To me, keys are keys and any name brand is probably just as good as another. I'd just stay away from no-name chinese made stuff, the metals they tend to use over there are cast and not very strong...
Old Feb 10, 2011 | 12:34 PM
Jake283's Avatar
Jake283
If im not mistaken, I think matt99 has a zone on his.
Old Feb 10, 2011 | 01:28 PM
HammerZ71's Avatar
HammerZ71
Coil Over, completely different type of kit.
