Factory rear VES in a 2007 Mega Cab?
Old Mar 9, 2011 | 01:10 PM
CBASS'sRam's Avatar
CBASS'sRam
The mounting bracket
Old Apr 21, 2011 | 10:39 AM
SJS67's Avatar
SJS67
does anyone know if the wiring is in the mega cabs already....read somewhere on here they come wired from factory for ves system....
thanks
so there is a bunble of wires going back to a white plug...you can kinda see in the picture....is that for the sat anntena?
Old Apr 28, 2011 | 09:39 PM
SJS67's Avatar
SJS67
anyone?
Old Apr 29, 2011 | 12:49 AM
Owensue's Avatar
Owensue
I found this on another site for you...
These are for the Dodge RAK radio and VES DVD player.
This is from a MOPAR website that your dealer has access to with out a vin number. It is for repair connectors. This is only for a connector, pins, and about 12 inches of wire. You will have to run you own wire to the radio to make the rest of the connections.
Mopar Package #
05102402AA repair connector
MEDIA SYSTEM-MONITOR/DVD - BLACK 12 WAY
CAV CIRCUIT FUNCTION
1 X510 20DG/LB RIGHT AUDIO AUX
2 X916 20GY/OR SDARS AUDIO RETURN
3 X521 20GY/LB LEFT AUDIO AUX
4 -
5 -
6 A118 18RD/OR FUSED B(+)
7 X511 20GY/LG LEFT AUDIO AUX
8 X910 20GY/DG AUX AUDIO RETURN/COMMON
9 X522 20GY/DB RIGHT AUDIO AUX
10 D55 20WT/OR CAN B BUS (+)
11 D54 20WT CAN B BUS (-)
12 Z957 18BK GROUND
Here is the corresponding connector pin out on the back of the radio.
Mopar Package #
05135638AA -reapair connector
RADIO C2 - GRAY 10 WAY
1 X16 20DG/YL AUDIO SIGNAL RIGHT (+)
2 X917 20DG AUDIO SIGNAL COMMON
3 - -
4 X510 18DG/LB VDO-AUX AUDIO RIGHT
5 X916 20GY/OR SDARS AUDIO RETURN
6 X17 20DG/OR AUDIO SIGNAL LEFT (+)
7 X910 18GY/DG AUX AUDIO RETURN
8 X511 18GY/LG VDO-AUX AUDIO LEFT
9 X521 18GY/LB VDO-AUX AUDIO LEFT 2
10 X522 18GY/DB VDO-AUX AUDIO RIGHT 2
You can get connectors from the dealer or.... http://dto.vftis.com/mopar/main.asp
Or http://moparpartsamerica.com
I found this info @ http://www.chryslerforum.com/forum/c...up-5608/page2/
Hope it works out, Good luck!
Old Apr 29, 2011 | 09:59 PM
SJS67's Avatar
SJS67
awesome thanks
