4x4 Auto light?
Old Feb 15, 2011 | 05:41 PM
terracedean's Avatar
terracedean
Default 4x4 Auto light?
08 5.7 4x4 1500, my auto 4x4 light wont go off tried switching it off and on switch to low, back up everything to do with the switch, and i just wont turn off, when i start my truck or try to turn it off it just flashes and then goes solid? any insight into this? thanks
Old Feb 16, 2011 | 04:06 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would THINK if you disconnected the switch and the lights went out, then maybe it is the switch that is causing the issue. Maybe a volt meter set fro a continuity check could verify the position(s) of the switch and help narrow down if thats the issue or not.
