Dome/map light simple question
Old Feb 18, 2011 | 06:58 PM
CaliDodgeRam's Avatar
CaliDodgeRam
Default Dome/map light simple question
For those of you who have replaced them where do you find is the best place to get them, I mean I've read tons of threads about leds being installed in the dome or map lights and then only working in strange instances or flickering. Thanks
Old Feb 19, 2011 | 01:52 PM
freddy53's Avatar
freddy53
I ordered mine off of supperbrightleds.com and they work great. They are also alot brighter, I have had many people coming up to check them out because they haven't seen anything like them. They just pop right in like the oem ones too. The only thing that is different from the oem ones is that they don't turn on if you just push the light on if the key isn't in the ignition. But on the plus side you dont have to worry about leaving them on in your vehicle.
Old Feb 19, 2011 | 05:58 PM
Marx's Avatar
Marx
another happy superbrightleds.com customer here as well, i turned ming facing up because they are so bright
Old Feb 19, 2011 | 07:22 PM
CaliDodgeRam
Thanks guys thats the site i was considering!
Old Feb 19, 2011 | 07:54 PM
BigHorn777's Avatar
BigHorn777
Which festoon bulbs did you guys go with from SuperBright? I bought some off of Ebay and 2 of them burnt out in less than 6 months and the last is flickering. The ones I got were pretty bright also, but not as bright as yours appear to be Marx.
Old Feb 20, 2011 | 02:38 AM
freddy53's Avatar
freddy53
Not too sure what Marx went with but my truck looks the same as Marx and I went with the High power festoon 4210-xHP6 and it is definitely enough light. I was pretty happy with their products. Next on the list is to try some leds for the reverse lights.
