Well I put on new set of BFG 37" KO and XD Rims. Now I have black set for fall and winter and spring and summer set. On the Calipers I used G2 Custom Color Match Brake Caliper Paint. Got extra set of tire pressure sensors those things are not cheap.
I used lots of brake cleaner, 2 wire brushes a small and medium size. I spent about 1 1/2 on each wheel just to get them spotless. Once I got the wheels cleaned I brushed a coat on each and waited 15-20 min between coats. I ended up with 3 coats on the wheels. I ran out time and did not have enough paint but I want to paint the center hub as well. So I am ordering 1 more kit.
It looks like you painted the brake pad itself? Did you buy any other brushes or did the ones in the kit work fine?
I did buy another brush but I did not need it. The kit come with one brush and once you mix the activator in the can you have about 3 1/2 hours to use the paint or it gets hard. So if you do this make sure you get all the wheels calipers cleaned off first. I was able to jack up the front and get both tires off and I cleaned calipers then I put the tires back on and moved to the back. Once I got the back cleaned I painted the rear first to completion and put the tires back on. I moved up front and took the 2 tires off again and painted the front calipers to completion. It would have been lot easier if I had lift so I could have taken all the tires off at the same time.
I did paint the outside of brake it just looked odd not doing so. I have a feeling it may not hold. Brake and some of the tight corners is was took me so long just getting them cleaned.
