Updated pics(tails,level,grill)
Old Feb 19, 2011 | 08:13 PM
lance0206's Avatar
lance0206
Default Updated pics(tails,level,grill)
Finally got finished with the grill inserts(plastidip),2" level(Rear)w/o removing o/l spring and tinted taillights n 3rd brake light(vht nightshades)......Taillights are more dim than I thought would be..whats the bulb size 3157? and whats my brightness options as far as "plug n play" bulbs go?http://s304.photobucket.com/albums/n...urrent=012.jpg
http://s304.photobucket.com/albums/n...urrent=004.jpg
http://s304.photobucket.com/albums/n...urrent=002.jpg
Old Feb 19, 2011 | 10:15 PM
reefguy89's Avatar
reefguy89
looks good and heres a little help.
Old Feb 19, 2011 | 10:20 PM
ram_bo06's Avatar
ram_bo06
Your truck is lookin real good. I like the aggresive street look of ure truck.
Old Feb 19, 2011 | 10:44 PM
Matt99's Avatar
Matt99
looks good. rims looks great like that. not crazy about the strip though
Old Feb 20, 2011 | 10:33 AM
dirtydog's Avatar
dirtydog
Moderate User
I likes! Your wheels look good. The tails look real good too, but when I did mine, I covered the clear reverse lens to keep the bulb brightness. As far as buying a bulb to put in there as a replacement, all 3157's produce the same output. If you go buying anything that says it's a hotter output, you'll likely ruin the contacts on the circuit board inside the tails. The ONLY tail light bulb that will be brighter than your stockers are goin to be overdriven bulbs(basically oem style bulbs with less internal resistance to provide more output wattage). This is what they do for bulbs like GE Nighthawks, Silverstars..etc the problem is they don't last as long because they are being overdriven.
LED bulbs will NOT be brighter. Even the one's with the 68smd chips on them that are an outrageous $50 or $60...lmao
There is NO led lightbulb that is capable of producing a brighter output light than a halogen bulb of equivilent size. LED's are directional and guys who say they are brighter are looking directly into the bulbs single vision path. Step to the side and the ouput is gone. Do the same with halogen bulbs....Head-on is bright and step to the side the output is still super bright. I could go on-on-on-on.....
Either get some back-up lighting like I did(mounted narrow height fogs to my leafs) but since you are lowered, maybe you can figure something else out. I think regardless of what bulb you find, even if it were twice as bright, it still won't be bright enough!
Old Feb 20, 2011 | 02:19 PM
ricer's Avatar
ricer
I was wondering how exactly you did your grill. I like that look alot and am very interested in doing mine the same way. I have never worked with plastidip so this is new to me. Did you remove your grill or just tape everything off? I have read in some other threads that using adhesion promoter helps to.
Old Feb 20, 2011 | 05:28 PM
CaliDodgeRam's Avatar
CaliDodgeRam
Agreed^^ working on the same project and torn between plasti dip and spray paint!
Old Feb 21, 2011 | 06:32 AM
lance0206's Avatar
lance0206
Plastidip is just as easy to use as spraypaint...This stuff sticks to anything without the need for prep work..All I did was took out the inserts wiped them clean then sprayed then..Ive done my gas lid,wheels and grill with this stuff and havent had a problem yet....
Old Feb 21, 2011 | 06:34 AM
lance0206's Avatar
lance0206
Thanks for the input I guess Ill have to figure something out!!!Do you just wire the extra lights to your brake light wire? Also mind posting a pic so I can get an idea? thanks
Old Feb 21, 2011 | 10:28 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah bud, thats looking really good. I like it also
