HELLA 500's Installed
Old Feb 25, 2011 | 12:14 AM
  #21
bgbluram2's Avatar
bgbluram2
It took me maybe 2 hours to get it all wired up today. I used the small blank spot on the dash where the power pedal button would be for my switch, it looks very clean and I ran the two wires through the firewall where all of the other wires were ran from the factory. I cut a lot of the supplied wire out because they give you about 40 feet in case you are wiring them to a school bus or something. Mine came out really clean. I will post up some pictures tomorrow.
Old Feb 25, 2011 | 12:26 AM
  #22
bgbluram2's Avatar
bgbluram2
Here is a picture that I took earlier of them on, they look so good in person.
Old Feb 25, 2011 | 08:32 AM
  #23
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by Steve/06 Hemi
Ya the wiring was really easy.What took the longest for me was just figuring out how i wanted to run all the wires so it didn't look all ghetto.
Thats always most important to me too
Old Feb 25, 2011 | 08:55 AM
  #24
lance0206's Avatar
lance0206
anyone got pics of how and where they drilled into?
Old Feb 25, 2011 | 11:37 AM
  #25
bgbluram2's Avatar
bgbluram2
I will post pictures of where/how I mounted them, how I ran the wiring, and the switch inside the truck today after I get out of class.
Old Feb 25, 2011 | 12:17 PM
  #26
lance0206's Avatar
lance0206
thanks
Old Feb 25, 2011 | 12:31 PM
  #27
Geezir's Avatar
Geezir
Damn Cummins. Not enough room for me to do this.
You should tap into your High Beams so they come on with your highs.
Old Feb 25, 2011 | 06:14 PM
  #28
bgbluram2's Avatar
bgbluram2
Here are some pictures that I snapped really fast. The first one shows where I mounted mine, I measured about 4" from where the cross member bolts together on each side so that they would be positioned equally on each side.
Here is a picture showing where I mounted my relay. It is simply held on with velcro for now because I couldn't find a place that I wanted to mount it permanently. As soon as I find a spot I like, I may move this, but it works for now.
And here is a picture of the switch that comes with the kit installed where the power pedal switch would be (obviously not an option on my truck) and this spot worked out perfectly because this piece can be removed to be drilled, and if for any reason I decide to take the lights off of the truck or sell it, this piece can be replaced with a new factory cap for about 7 dollars.
Let me know if you want any more pictures of anything. Comments and criticism welcomed
Old Feb 25, 2011 | 06:41 PM
  #29
BadHab1t's Avatar
BadHab1t
actually hammer i think the state of fla says no more than 2 sets of driving lights on at a time so 4 lights would be 2 heads and 2 fogs, i ride with my hellas on and havent had any issues, i also ground out the bottom for better aiming, down that is...
Old Feb 25, 2011 | 06:44 PM
  #30
Blacksport's Avatar
Blacksport
Nice job!! I think I'll be putting on a set!
