Trac lok LSD?
Old Feb 27, 2011 | 10:03 PM
T-Muns's Avatar
T-Muns
Default Trac lok LSD?
I'm about to order a 4.56 gear package (4x4) for my truck. I have 3.55 w/ open diff right now. I obviously want a lsd, but I just spent $ on an engine swap (among other things) and gears are expensive, so an Auburn or Detroit is a little out of budget.
If I can find a deal on a low mileage trac-lok, should I go for it? Or am I better off waiting until I can afford a better one? Thanks
Old Feb 27, 2011 | 10:12 PM
T-Muns's Avatar
T-Muns
I should mention I'm going to pay someone to do the gears because it's not something I want to take a chance on screwing up. That's why I'm wondering if I should get the lsd done now.
Old Feb 27, 2011 | 10:17 PM
MikeHTally's Avatar
MikeHTally
Well, it's probably a good thing to only open up the diff once. I'm in the same boat, kinda. Different gears and a different LSD will probably run about $1,200. Lotsa moola for questionable return.
Old Feb 28, 2011 | 07:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I agree. If you know you are going to get an LSD later and you are already going to pay someone to do the work for you, then i would wait and save some coin and do it once
Old Feb 28, 2011 | 10:24 AM
T-Muns's Avatar
T-Muns
So I guess that's a "no" on the trac-lok?
Old Feb 28, 2011 | 12:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats up to you. I had one that came with my truck and worked fine for what I needed. The only reason I changed was because i ran across a deal i could not refuse
Old Feb 28, 2011 | 07:15 PM
Powerubi Wacon's Avatar
Powerubi Wacon
The Dana Trac-Loc is barely effective when new. They are practically useless after about 50,000 miles because it is a clutch-type (constantly wearing) limited-slip. Your money would be better spent on a gear-type limited slip such as a Detroit Trutrac.
I have a Jeep Grand Cherokee with the Dana Trac-Loc and a Dodge Ram & Jeep Wrangler with (factory) gear-type limited slips (in addition to the factory lockers). Let me tell you...night and day difference. I can go pretty far off road with the Ram & Wrangler in 2WD before I need to engage 4WD.
Do it once and do it right.
Old Feb 28, 2011 | 08:44 PM
T-Muns's Avatar
T-Muns
Thanks guys. I think I will keep looking for a deal on a better lsd or locker....might as well just get em done all at once.
Old Mar 1, 2011 | 01:21 AM
Powerubi Wacon
No problem. A wise choice. It is always better, yet tougher, to wait until you can do it right rather than being in a hurry and settling for something that you will not be happy with in the long run. Good luck!
