TPMS Problem
Old Mar 2, 2011 | 08:12 PM
Mike-SS's Avatar
Mike-SS
Default TPMS Problem
My TPMS warning light has been coming on non-stop. I have stopped and filled my tires, and or checked the pressure multiple times. I have non-factory tires and the suggested pressure for the tires is a max of 50 PSI. I have the tires at 50 psi and the light still comes on. Is there possible a confusion between the computer and the newer tires? The computer may be looking for a higher or lower psi?
HELP!
Old Mar 2, 2011 | 08:39 PM
MikeHTally's Avatar
MikeHTally
They'll react to too much pressure as well as too little. Why would you ignore the door placard for tire pressure?
Old Mar 2, 2011 | 08:47 PM
Mike-SS's Avatar
Mike-SS
Not ignoring any tire pressure. As I said in my original post I have the pressure set per the tire, which is not the factory set of tires. Pressures will be different based on tire.
Old Mar 2, 2011 | 08:53 PM
MikeHTally's Avatar
MikeHTally
Wrong. The tire manufacturer doesn't set the pressure. The door placard determines the proper inflation pressure.
Old Mar 2, 2011 | 09:18 PM
Mike-SS's Avatar
Mike-SS
Okay.....brain fart on my part....
Just adjusted tires to the recommendation on the door...35 psi. TPMS light still comes on!
Old Mar 2, 2011 | 09:26 PM
MikeHTally's Avatar
MikeHTally
You will likely need to drive it some. The sensors are off if the wheels aren't turning. Makes the batteries last longer.
Old Mar 2, 2011 | 09:27 PM
Slava's Avatar
Slava
This is not exactly correct. The door placard shows pressure for OEM like tires, for my truck for example it will be P265/70R17 tires. For such tires max pressure is 50 PSI so the proper pressure under normal condition is 35 PSI (according to the calculation max * 0.7). Many people here run at 70-80% pressure of the max which is considered to be normal. If, for example, aftermarket tires are 10ply tires with max pressure of 80 PSI the proper inflation will be 56 PSI - 64 PSI.
Old Mar 2, 2011 | 09:28 PM
MikeHTally's Avatar
MikeHTally
Come to think of it, does it use sensors? Some systems use the ABS system to detect the tiny changes in wheel speed to guess that the tire is too low/high. Are the valve stems flexible or rigid?
Old Mar 2, 2011 | 09:31 PM
Slava's Avatar
Slava
Before getting into the troubles with computer I can suggest 2 possible solutions:
1. Change all TPMS sensors in your tires
2. Or take them out and disable this function in your computer
Old Mar 3, 2011 | 07:55 PM
Mike-SS's Avatar
Mike-SS
Took the truck for a nice drive this morning after setting TP to 35psi. No change.....
Truck under warranty still....
Dealer found that sensors were not programmed. Problem solved.
