clearance lights smoked or amber
Old Mar 18, 2011 | 03:18 PM
Matt99's Avatar
Matt99
smoked. I think chrome would be a little too much
Old Mar 18, 2011 | 05:37 PM
Deathrend's Avatar
Deathrend
I've been thinking about adding the lights to my truck, I'm just unnerved about everything involved.
I've been thinking about having the dealership install a stock set, but I'm not exactly sure what that would run. I'm sure it wouldn't be cheap though.
Old Mar 18, 2011 | 05:56 PM
Matt99's Avatar
Matt99
yea i would like to do em but its scary to drill a ton of holes in your roof
Old Mar 18, 2011 | 07:27 PM
HammerZ71's Avatar
HammerZ71
Hell, I did it long before there were DIYs or anything. If you get a template or measure carefully, you are golden. Also remember, silicone is your friend!
In my case, I also found a six pack right before drilling the holes helps with the confidence factor.
I used the clear ones from Recon (where we get a 15% discount btw), mainly because I wanted the chrome bases to match all my stainless steel and diamond plate trim, but I've often thought about taking the clear caps off and replacing them with smoke ones.
Old Mar 18, 2011 | 09:57 PM
JDG103's Avatar
JDG103
Hammer if i was you i would replace the clear with smoked...IMO it would look great smoked....im still not sure what kind i should get for mine
Old Mar 18, 2011 | 10:02 PM
Deathrend's Avatar
Deathrend
Those are the one's I've been eying for months now.
Do you just wire it into the parking lights? Not sure how it works without the stock lights, and I'm running out of places to mount switches, rofl.
Old Mar 18, 2011 | 11:34 PM
Geezir's Avatar
Geezir
the harness is already there in your truck. behind your passenger a-pillar cover.
Old Mar 19, 2011 | 09:56 AM
dodge1hemi00's Avatar
dodge1hemi00
The place were I go will do it for $130 all parts included and they just come rite on with ur lights so I think that a fair price
Old Mar 19, 2011 | 03:57 PM
HammerZ71's Avatar
HammerZ71
That's not a bad price at all. I had like $80 in the lights and it took me a good 2 1/2 hours to install it. I'd be able to do it in prolly about an hour and a half the next time though, I got like paranoid **** about measuring before I drilled the first hole.
So if you got someone to do well over an hour in labor for $50 (assuming they have about the same $80 in lights and materials) then that's a SUPER deal. I just hope they don't leak on you, all too many times there is a reason why someone charges a good bit less for their labor than the going rate.
Times sure are changing. Used to was most of the enjoyment of modifying your vehicle was doing the work yourself...
Old Mar 20, 2011 | 11:21 AM
dodge1hemi00
They did a set on my 98 dodge did a great job on them
I like doing al the work myself but somethings just worth it if the price is so cheap
