Help Choosing the right fluids
Old Apr 30, 2011 | 02:33 PM
1987notchback's Avatar
1987notchback
Default Help Choosing the right fluids
hey guys about to change the fluid in my tranfer case, tranny fluid/filter and rear diff oil/friction modifier. whats the best way to go? is royal purple worth it? as these fluids are changed as the manual calls for it i do not mind spending a little extra $ to get better quality but if not needed i will not. thanks mike
Old Apr 30, 2011 | 02:45 PM
Truckin513's Avatar
Truckin513
Royal purple is worth the money. But as an alternative I would suggest Lucas with the additives in it. And its always best to change them as its not worth having something overheat and break then you are out BIG $$$
Old May 1, 2011 | 01:16 AM
Owensue's Avatar
Owensue
Any reputable brand atf4 for the tranny & transfer case, unless you want to pay double for synthetic. I was going to but it was not stocked at my local suppliers. I used mobil1.
Old May 1, 2011 | 08:17 AM
1987notchback
i am leaning towards royal purple, if i use it for my rear diff do i still need to add friction modifier? from what i read it seems i do not?
Old May 2, 2011 | 01:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have RP in my engine, trans and diff.
We have a polled thread on this in our FAQs BTW.
Old May 4, 2011 | 03:24 PM
Truckin513's Avatar
Truckin513
No if you go with RP the additives are already in it.
Old May 4, 2011 | 04:41 PM
HammerZ71's Avatar
HammerZ71
I like RP, but to be honest, I have a health problem right now and am not working full time, so I just went with Valvoline full synthetics on both of my recent fluid changes in the truck & the Jeep.
RP is good, but you really can't go wrong with any name-brand 100% true synthetic...
Old May 19, 2011 | 06:16 AM
1987notchback
hey weed how many miles do you go in between changes with rp?
Old May 19, 2011 | 07:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My rear oil I try to change between 20-30k
Old May 20, 2011 | 08:08 AM
1987notchback
how about engine oil? how much is rp oil and filter? just curious if it is worth the extra $ i have run valvoline synthetic since i bought the truck
