I Know This is Way OT But I Need Some Help...
Old Aug 3, 2011 | 04:49 PM
  #31
truegent81's Avatar
truegent81
So finally got some results from this shop. 1st shop I tool it to said oil pump and the at they were getting good psi at idle but when warmed up it dropped to 4.5psi. Second opinion they did test on pump and they told me warmed up it was at 12psi which is just fine. They said had it gotten to 4.5 it would've been bad.
I didn't tell them I had the oil pump checked earlier. I bet that shop just wanted to make $1100. Instead she has 4 collapsed valve adjusters and worn timing belt. Decided to replace those 4, timing belt, balance belt, water pumP, front seals and gaskets for $1100-1200. Parts and labor. Bout damn time.
