how does my pinion angle look?
Old May 12, 2011 | 07:22 PM
twothousand6's Avatar
twothousand6
Default how does my pinion angle look?
Horrible!?
http://tinyurl.com/3fcpud4
Old May 13, 2011 | 10:35 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I fixed your link and it look fine. Why do you think something is wrong with it?
Old May 13, 2011 | 12:38 PM
twothousand6
thanks for the fix, I am getting vibrations throughout the RPMS, I feel like it got worse. Im going to shim it soon. I was just looking for some extra input becuz Im having a hard time with it lol
Old May 13, 2011 | 01:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
pinion angle looks good but it could be a bad or loose U joint. I would put the rear on jack stands, put it in D and slowly build speed so you can see if it is coming from the rear end or drive shaft or not.
Old May 14, 2011 | 01:01 AM
freestyledude's Avatar
freestyledude
I'd put it on jackstands and shake the driveshaft, it's most likely worn u-joints. Definitely not the pinion angle causing your issue
