Big Money Saver Codes From AAP
Old May 31, 2011 | 05:08 PM
NHHEMI's Avatar
NHHEMI
Default Big Money Saver Codes From AAP
These are some really good savings at AAP. These codes all work as of 5PM EST. You must order online to use them but you can select store pickup if the item is in stock at the store of your choice.
I used one of these today and saved $35 off a battery and a friend used one and saved $25 on an ignition coil. Just note these codes will not work with oil or other fluids. Any other part pretty much though.
Just thought I would share...
P20 = 20% off any order
A123 = $10 off $30 or more
A123 = $20 off $50 or more
A123 = $30 off $100 or more
BIG25 = $25 off $60 or more
BIG30 = $30 off $75 or more
BIG35 = $35 off $85 or more
BIG50 = $50 off $200 or more
JN15 = 15% off $100 or more plus $50 coupon good toward next purchase of $100 or more.
Go to http://www.advanceautoparts.com and select your item(s) and then apply the appropriate promo code based on how much you spent in the shopping cart view before checking out.
Old May 31, 2011 | 10:12 PM
dodge1hemi00's Avatar
dodge1hemi00
some good deals
Old Jun 1, 2011 | 05:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
THX for sharing
