Hemi fitment into a v6??
Old Aug 4, 2011 | 09:53 PM
jpc200878's Avatar
jpc200878
Default Hemi fitment into a v6??
I have an 02 1500 single cab 3.7 v6 5speed I was wondering if the 5.7 hemi fit in my truck????and where can I find all the parts I need
Old Aug 4, 2011 | 09:56 PM
xjfever's Avatar
xjfever
Your best bet would be to find a wrecked one with the hemi engine. You will need lots of small parts that will add up quickly if you just purchase the engine and tranny. With a wrecked one you will have all you need.
Old Aug 4, 2011 | 10:29 PM
bgbluram2's Avatar
bgbluram2
Yes, the truck is the same so the engine would fit just fine. But you will need the computer/transmission/wiring harness'/etc.
Old Aug 5, 2011 | 12:21 AM
HemiLonestar's Avatar
HemiLonestar
Engine/trans, full harness with computers for both, correct front springs, possibly different driveshaft, different radiator (for starters).
Old Aug 5, 2011 | 01:30 AM
Owensue's Avatar
Owensue
Engine mounts.
Old Aug 21, 2011 | 12:58 AM
Plainbroke's Avatar
Plainbroke
exhaust, radiator,radiator shoud,overflow tank, motor mounts, trans mount, trans lines, rad hoses, intake, not sure if fuel pumps put out the same PSI and flow rate. computers BOTH of them. Front springs unless you want to lower the ride height an inch or 2. drive shaft, Full wireing harness. and someone good at grafting the 2 together.. Probably a dozen things I have forgot..
