24v to 12v
Old Sep 13, 2011 | 11:22 PM
Rammin It's Avatar
Rammin It
Default 24v to 12v
Does anyone know if you can rewire a 24 volt winch to 12 volt? Found a 9 ton industrial Warn winch (new, never used ) for $500.00. If this is possible ,should be able to hang my truck from a tree.hahaha
Old Sep 13, 2011 | 11:26 PM
drewactual's Avatar
drewactual
Man, it would be easier to get a couple 12v batteries and run then in series independent of the trucks system, and run a charge to one in parallel, which will trickle the other. You gotta put a post in between them so you don't fry anything, but I've seen and done it in reverse on military vehicles..
Old Sep 14, 2011 | 09:16 PM
lxman1's Avatar
lxman1
Site Moderator
You would have to have the motor rewound. That's where the difference is.
