ram 1500 burns too clean
after failing inspection 3 times because emissions levels were to low I took the truck to my mechanic expecting a bad leak somewhere bad he called and wanted me to come talk to him Im thinkin bad news but when I got there he told me it has no leaks and just burns too clean to get enough of an emissions level its got magnaflow dual catback exhuast system anyone ever heard of a v8 hemi burning to clean ?
nope. its an exhaust leak. no such thing to be TOO clean you dont pass. Its usualy something like 10% under the requirement level and they automatically fail you for an exhaust leak. You wont be under by 10% on all categories at one time unless its a leak. Ex: if its not an exhaust leak and your under 10% on CO2, youll be over on NOX. GL tracking it down.
I found 2 quarter sized holes and had a patch welded on both searched both pipes up to were they join the manifold and couldnt hear or feel anything like a leak went back through and got the same emissions reading minimum for DE is 6.0% it read 4.85% all three times at the dmv the mechanics checked everything that couldve caused the problem but found no leaks Il try in the morning and il go through cold maybe it will pass
reef im in lewes good to see someone else local
Trending Topics
burns richer cold because it's dumping more fuel... cold engine needs more catalyst to positively ignite the mix..
wanna find an exhaust leak? grab up a buddy, and grab a can of seafoam.. let the seafoam suck in the brake booster slow enough not to kill the engine, and enjoy the smoke show while you talk your buddy into crawling around under the truck looking for smoke NOT coming out of the tail pipe..
are you running a programmer? you sound like your running too lean.. if not a programmer at fault, you may want to look at engine temperature sender, and/or IAT.. those two can lean out an engine.. so can your o2 sensor..
