Oldschool dual snorkel good as vararam?
Maybe I should ask it this way...
How will you connect both snorkel tubes to the throttle body?
That's what I'm curious about... Did you already find something to replace the resonator box at the throttle body that would house the filter? I haven't seen any except for what comes with the Veraram. If you have found something, please share that info with us!
Truckin - Do you know what the CFM numbers are for vararam? Also, are the tubes 3" or 4"?
Snorkel tubes hook to the air cleaner (filter inside). The challenge is hooking the air cleaner to the throttle body. I found a low profile snorkel airbox from spectre that might work. I'm going to try to connect it to the throttle body with a 90 degree pvc elbow.
http://www.vararam.com/hemi.html
Towards the bottom they have a air flow test.
As for the tubes, I believe they are 5"-6". Here is the leftover tubing I had compaired to a 4" inside diameter piece of pvc pipe.
Trending Topics
Cool, thanks for the info. I didn't realize the tubes were that big. I was wondering about the tubes because I bought this spectre kit from advance auto with a discount code for $109:
http://www.spectreperformance.com/#CATALOG.728
It has 4" tubes. It will be interesting to mount up, but I've done some rough measurements while holding the air cleaner over the engine and I think it's going to work. I found a huge grommet that will make the air cleaner have a 4" opening at the bottom, so I can use a 4" elbow with a 4" to 3" reducer to the throttle body.
Going to mount on the bumper like vararam and will most likely use dryer duct style scoops like this
I'm hoping it will be the poor man's vararam!
