please help, truck wont start
Old Nov 5, 2011 | 07:43 PM
jonheath84's Avatar
jonheath84
Default please help, truck wont start
ok here is the deal, while driving down the road my truck died, dash lights, radio,all electronics still working and it wont start back up.it will turn but wont start.it threw 3 codes 2110,2111,2106 all pertaining to throttle actuator control system.i replaced the throttle body and that cleared my codes.i put a new cam pos sensor,and crank pos sensor.i also changed plugs and new battery.i have 50 pounds of fuel pressure a the rail and with a plug tester determined i have spark.still will not start.ANY HELP WILL BE GREATLY APPRECIATED!!!!thanks in advance
Old Nov 6, 2011 | 12:37 AM
Caseys-dodge's Avatar
Caseys-dodge
If you provide a bit more info like year and engine size that will help the experts be able to help you. Also anything significant happen to the truck before this problem occurred (like any maintenance performed, or has it acted up before, or is this the first sign of trouble). With enough background info the suggestions should start posting!
