Old Aug 17, 2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
K&N air filter question
Old Dec 11, 2011 | 05:09 PM
  #21
HammerZ71's Avatar
HammerZ71
Originally Posted by NV290
First and foremost, realize that your underhood temperature is not only caused by the radiator. You also have two MASSIVE cast iron exhaust manifolds, plus your cylinder heads kicking off heat. The higher the RPM's, the hotter those manifolds get and they are not in the direct airflow of the radiator. They are a huge factor in underhood temperatures.
You are right that at high speed the air flow through the radiator will cool your engine water temp down without needing the fans. But the exhaust manifolds are still pumping out heat. The split air filter housing you have is putting each air filter right above each manifold. If their was any real advantage to having warm air for induction to give better MPG, then why does *******ly no car company mount at air filter in a location where it draws in hot engine compartment air any more? Car companies nowadays are doing ANYTHING they can to increase MPG by even half a gallon. GM recently announced that a Spare Tire would be an OPTION on some cars to shave off weight. That should give you an idea of how crazy these companies are with increasing MPG. With that being said, the fact none of these companies have stopped installing air intakes that draw cold air that is away from the engine and the airflow from the radiator is all the proof you should need that warm air does not increase MPG in any way.
Not saying you, but i am amazed at how many people seem to doubt car manufacturers engineers when it comes to designing engines. All these major car companies invest millions of dollars to squeeze out as much horsepower as possible using as little fuel as possible. The two biggest numbers car companies love to flaunt are MPG and HP. They know far more about engines then almost any of these aftermarket companies and know what works and what does not. That is why i laugh at things like a throttle body spacer claiming it will add 10 HP. Right, like Chrysler Engineers were too stupid to think of that. It's all BS. And if they could squeeze 10 more HP out of an engine by simply using a different style of air filter, you honestly think they would not do it?
The only exception i have ever seen with car maufacturers not using a proven idea to get more Horsepower is if it does any of the following four things:
1. Makes the vehicle too loud. (Free flow exhuasts as an example)
2. Hurts reliability/Increases maintenance.
3. Lessens MPG.
4. Hurts emmissions.
Taking those four things into account, if it does not do any of those things and the car company did not install it, it likley is not worth installing on your own.
And you REALLY think that the engineers get final say of what goes into the manufacture of a vehicle? I've sat in on open discussions with engineers and trust me, very little of what they want to do/see in a vehicle makes it to final production. Bean counters are who decides what goes into a vehicle - ask any motor vehicle company engineer...
Old Dec 11, 2011 | 06:02 PM
  #22
NV290's Avatar
NV290
Originally Posted by shelbymopar89
I like the fact that I never have to buy another filter. Normally just clean it when I am messing around in the garage some weekend.
Yes, but if the reason you like not having to buy another filter is because you think you actually are saving money, the truth is you are not. In fact, i found a website that carries Ram paper filters for less then $10.00 each. And if it's not cost, but the "hassle" of going out and buying another Paper filter, realize that it will always be much less effort then cleaning and re-oiling a K&N filter properly.
I have (no joke) SEVEN auto parts stores within 10 minutes of me, PLUS a Walmart. I have no reason from a cost standpoint or a conveniance standpoint to buy anything from K&N.
Old Dec 11, 2011 | 06:10 PM
  #23
NV290's Avatar
NV290
No, i don't think that at all. But i do know that in this day and age, MPG and HP are the two biggest numbers car buyers look at. The higher those two numbers are, the better a car will sell.
Mounting an air cleaner on the throttle body itself would clearly cost less money to manufacture and install then running a tube from the throttle body over to the side of the engine compartment and having a filter in a seperate airbox plus all the assorted hardware and brackets. So that is a prime example of how added cost is justified when it means higher MPG and HP. Why are they going to that effort and expense if an air filter sucking hot engine compartment air from right on top of the engine gave better MPG and performance?.
Old Dec 11, 2011 | 06:52 PM
  #24
NV290's Avatar
NV290
Originally Posted by RAMRIG
NV290 you sound like a very knowlagable person, I'm not going to wrestle with you on your reply to my comment because you make allot of sence but in the same breath everything you said about the energy radiating off the block and exhaust mannifolds is an obvious fact if the engine was sitting in a dyno room where air is for the most part static, in a vehical travalling at 60 mph the math changes,
First off, to adress the statement that at 60mph the math changes as far as engine compartment tempatures.
I agree with that, 100%. A huge amount of airflow into the engine compartment will drop underhood tempatures. But travelling at 60mph all the time is completley unrealistic. What about stop and go traffic, city driving and driving in small towns? I work in a town that is almost 8 square miles and the fastest speed in town is 30mph.
Even in the Dyno cell, they use two massive fans to blow outside air through the radiator and engine compartment. It's not as effective as actually driving down the road at 60, but it's much more effective then actually sitting in traffic or driving around town at 10-15mph.
You are talking about how effective the setup is at highway speeds, but unless you only drive your truck at the track, that is a completley unrealistic way to justify your setup. Unless i am driving to one of my jobs which are both two highways away from me, 99% of my daily errands trips and driving around town might see 40mph tops.
I respect what you said and drawing from that I have a question for you after my thermocouple test I plan to install a foced air hood scoop and fab a plexiglass housing arround my filter setup totally sealed to the hood when closed, now back to the question will this decrease my mpg do to the fact that air temp sensor and mass airflow sensor will be noticing a change and be dumping more fuel into the engine and can my program in my processor keep up with the change? or because of the obvious increase in HP that I will aquire mean that I dont need to open the throttle as much to maintain the same speed in return have better mpg? what is the math on this?
Hope to hear from you
MIKE
BRAMPTON ONT. CANADA
it's cold up here eh!
I am no expert on EFI mapping so i cannot comment on how your truck will handle what you are planning. It could certainly do tuned to work well in that application through programming, but how you would do that and with what paramaters i cannot tell you. Ram air systems do work, that is documented and drawing in cold air from outside the engine compartment will certainly help performance. But when Dodge built your truck, they were not thinking about you adding Ram Air.
My truck does not have a MAS, it uses a Speed Density based system. Not sure about yours.
Technically speaking, a MAS is designed to measure the volume of air being used by the engine, not the temperature of the air. If that were the case, imagine the MPG fluctuations you would see between summer and winter? An MAS does have a seperate device in it that measures air tempature of the incoming air. It uses the air tempature combined with how much air to decide how much fuel to use. Not just temperature alone.
Cold air is more dense which means you can pack more of it into a cylinder which means more complete combustion. You will often see an MPG increase with colder air then you would with warm air. Because again, the MAS is measuring how much air your engine gets AND the temperature of that air. If you take the same quantity of air but at tempatures that differ by 50 degrees, you are not using more fuel, but you are getting more complete combustion and in turn, more power since the fuel/air charge is now more effecient.
Good luck in your experiments. Nothing wrong with trying new things.
Old Dec 11, 2011 | 07:03 PM
  #25
04HemiGreg's Avatar
04HemiGreg
That's why paper filters are still available. We don't all live in the city or suburbs where we just have to find the right one of the 7 stores within 10 miles that has what we need. I have 2 auto parts stores and a Walmart. And it's not that great a Walmart either. 90% of the time I need something more than oil changing supplies, there is at least one part I need that is out of stock. Happened again today. Went to both stores and neither had radiator hoses to fit my truck. Both said - "but we can order them for you". Hell, I may as well order them myself. If I have to wait for them, that's 2 round trips to the store I'll save and will probably get cheaper online anyway. It may cost me a few dollars more to keep my K&N, but I already bought it. So, at least for an air filter, I don't have to go to 3 stores only to find nothing is in stock and wait for them to order it for me.
The mom and pop retailers around here are always griping about how the online retailers and walmarts of the world are killing them slowly. They need to realize that brick and mortar shops are a matter of convenience for consumers and many of us are willing to pay a few bucks more to get what we want, when we want it. But in the last 10 years, I've owned a couple of Jeeps, a couple of Toyotas, a Mazda, and 2 RAMS. And I almost never seem to find what I need/want in stock. It may only be one part of what I need that they don't have but it may as well be everything in some cases. Last time I changed the plugs in my truck, they had 11 in stock and had to order the other 5 for me. I might as well have just ordered the whole 16 myself.
Old Dec 11, 2011 | 07:08 PM
  #26
shelbymopar89's Avatar
shelbymopar89
I have owned my Daytona Shelby for 18 years now and have had a cone filter on it for that time. I am quite sure I have not spent $180.00 (your $10 figure times annual replacement of 18 years) in maintaining my K&N. The longer you have a vehicle the more it pays for itself, so if you are one that trades it in every couple years maybe it would not be worth it for you. From a performance standpoint, I can't feel a difference. I can say that this filter has held up to me running 28 LBS of boost for the last 10 years, I have seen a lot of paper filters get sucked in. I am right there with you on the engine bay hot air, that's why I routed mine the way I did.
Old Dec 11, 2011 | 07:17 PM
  #27
Boo Radley's Avatar
Boo Radley
as some have said the intake alone does not much but when you put on mods that need the air they help those mods. my pop and i dominated the local track rounds when i was a teenager and all our build ups had a cai. go to nascar and look at those cars they all have a cai and take the air usually threw two huge rectangle intakes right at the scoop under the cars. if a cai didn't help performance you can bet your *** the nascar guys wouldnt tune them.
one of our sponsors was aem and we ran there intakes on all our buildups and never had an issue with an engine we could blame on the intake or even dirty oil for that matter. look at the agressive cam makers they all say to use headers and cai with them.
Old Dec 11, 2011 | 08:19 PM
  #28
RAMRIG's Avatar
RAMRIG
Thanks NV290 for your replies I will let you know how my results come out.
MIKE
Old Dec 11, 2011 | 08:26 PM
  #29
SLT8's Avatar
SLT8
I know i love my cone filter.
Old Dec 16, 2011 | 02:04 PM
  #30
gidy34's Avatar
gidy34
Ok, Looking for some advice on this topic. I have a K and N CAI, and a flowmaster exhaust. My concern is what has been said in this thread about excess air causing a push for more fuel, resulting in poor fuel economy. Is my computer adjusting or over compensating? Do I need some sort of adjustment done to the computer or possibly a tuner of some kind. I know my fuel economy is never going to be great, but i am afraid it may be worse than if I had just left it all stock.
