Leveling Kit/HID kit?
Old Dec 11, 2011 | 05:56 PM
RanchinRam's Avatar
RanchinRam
Default Leveling Kit/HID kit?
Alright, 2 questions I have for you 1500 2WD guys...
First off, I would like to do a 2 or 2.5" level of the front for the obvious reason. However, I can only find the coil spacers due to having a 2WD, and I believe they are made by Truxx and DayStar. I've seen a lot of talk about the Bilstein 5100's, but they are only for 4x4. Question is, have you guys found a shock that will level the front end, instead of using coil spacers? And if not, are the coil spacers safe/reliable?
2nd Q: After doing hours of research on HID kits, I planned to order a lowbeam and fog kit (6000K, 35W) from RetroSolutions, since they are priced well + lifetime warranty, and have specific Ram kits. I have noticed though that many bash just getting the bulb kits because of light scatter, and obsess over getting projector headlights or the Angel Eyes to avoid the issue of blinding oncoming drivers. Is the HID bulb/ballast/relay kit going to be fine by itself, or is it worth it to get the whole headlight assembly?
Thanks for any input/suggestions you have!
Old Dec 12, 2011 | 01:16 PM
RanchinRam's Avatar
RanchinRam
66 views and nothin?? C'mon someone's gotta have ran into at least one of these two problems! haha
Old Dec 14, 2011 | 12:28 AM
CharlieEscobar's Avatar
CharlieEscobar
Nah man just kidding. I'm looking for threads on HIDs for my new toy. Don't know crap on how to do it.
Good luck.
Old Dec 14, 2011 | 07:29 AM
Catchin Zs's Avatar
Catchin Zs
If coil spacers are your only bet, go for it. And for the HIDs, no need to buy the whole light assembly, just replace the factory bulb in the housing with the HID bulbs you bought.
Old Dec 15, 2011 | 03:27 AM
Brandon Anderson's Avatar
Brandon Anderson
First, there's no such thing as a shock that levels a 4x2, because the "shocks" everyone talks about to level the 4x4 are actually struts. This is how lift is achieved on the 4x4, and why it will never work on a strut-less 4x2. Second, while coil spacers are certainly an option for the 4x2, your best bet for leveling is the 3" lift spindle. You'll get an almost dead-on level after the alignment, and they're easier to install, IMO. Big plus for the spacers is how cheap they are, and I actually have a set of 2" spacers if you're interested in them.
Light scatter is a pretty big issue with HIDs in any reflection-based enclosure that was not designed for HIDs (like our trucks). However, installing just any ole projector housing off of ebay isn't going to help you out either. All of those cheap projector kits (including nearly every set of "angel eyes", which is merely a term for the illuminated halo surrounding the projector) will really hurt your light output and pattern, regardless of whether you use halogen or HID bulbs. If you care about not blinding passing motorists, you will need to retrofit proper HID projectors into your stock headlamp housing. This is neither easy nor cheap. That being said, it is not required for the use of HID bulbs. Some people just aim their headlamps a little towards the lower right, which will help with the glare for others, but doesn't do much for your nighttime visibility. What you choose is ultimately up to you and your budget or know-how.
Old Dec 16, 2011 | 09:19 PM
timekop's Avatar
timekop
Default RC 3" lift
Rough Country has a 3" in front and 1 1/2" in rear, using coil springs in the front and blocks in the rear. The kit also has shocks all the way around for less the $300.
Old Dec 17, 2011 | 07:03 PM
CaliDodgeRam's Avatar
CaliDodgeRam
I almost leveled mine, but then talking to the local pre-runner guy and friend who runs a pre-runner shop, he said he has seen way to many headaches of leveled 3rd gen rams and that you run the risk of having front end problems when ever you level our trucks. Just my input.
Old Dec 17, 2011 | 07:44 PM
RanchinRam's Avatar
RanchinRam
Hey thanks all for your suggestions and advice. I've decided against leveling it, just for the fact that I had a feeling in general that there'd be front end issues eventually if I did it, and I don't want any issues like that. Regarding HID's, I definitely want improved nighttime visibility, since the Sylvanias I put in just didn't cut it. However, I'd like to do it right and not take the easy way out, so I'll look around for projector housings for it.
Old Dec 19, 2011 | 12:30 AM
Brandon Anderson
Raising the front of our 4x2 Rams using the spindles causes absolutely no more stress on any front end component than stock. Using the coil spacers will adversely affect the truck eventually, especially for the '06+, but your ball joints and tierod ends will fail before that happens anyway. If you had a 4x4, then yes, any amount of lift will cause components to wear faster, especially the joints on the front axles.
Old Dec 19, 2011 | 06:42 AM
Cthulhu's Avatar
Cthulhu
For HIDs, go with jj at retro soln's. I've heard nothing but good. Not cheap, but definatley good!!
