35's question
Old Feb 14, 2012 | 09:46 PM
rideon20z's Avatar
rideon20z
Default 35's question
looking into some new rims and tires , i wanted to know if i can get 35's under my 04 without a problem ? i leveled it out and it has a 3 in BL , can the 35's fit without any rub ? its a 4x4 if that makes a difference ? thanks guys if you can hel !!!! would be greatly appreciated .
Old Feb 14, 2012 | 10:49 PM
Mad_Scientist's Avatar
Mad_Scientist
https://dodgeforum.com/forum/3rd-gen...dodge-ram.html
Old Feb 15, 2012 | 06:13 AM
rideon20z's Avatar
rideon20z
thanks Mad , i did see this after i posted , sorry for taking up space ,! just wanted to make sure all was good before i make such a pricey purchase !
Old Feb 15, 2012 | 07:55 AM
Devils_Advocate's Avatar
Devils_Advocate
just t-bar cranked, and 1/4" spacers. stock rims. NO RUB at full lock, no bumper trim.
https://dodgeforum.com/forum/3rd-gen...nd-on-35s.html
Old Feb 15, 2012 | 08:44 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
Yes, unless you go with some ungodly wide tire. A 35/12.5/17 (you AAAAAARE going with 17's, right? ) will fit without issue. I came across a bunch of early 3rd gen's with 3" BL's only in my research for tires that were fitting 35's under without issue. I went with 33" tires, again, but that was only for economy and practicality.
Old Feb 16, 2012 | 09:02 PM
rideon20z's Avatar
rideon20z
im going to go with a 20x9 with a 325-60-20 nitto terra grappler tire , i think i found my set up now i just have to order them !!! i will update my signature when i get them mounted . thanks guys
