Exhaust question (probably covered but cannot find it.)
What size are the pipes if I was to cut out the factory Y-pipe on my 04 1500 hemi? I was planning on ordering http://www.flowmastermufflers.com/shop/index.php?main_page=product_info&cPath=0&products_ id=4410&ab=817513&recordID=485&vehicle=&orig=81751 3 and the Magnaflow 10778 Y pipe. Also, after the factory Y is cut out will the Magna Y fit right in or will I need to do some tubing work?
Out of all the exhaust systems and mufflers i have put on or been apart of have included tube work along with maybe some welding which i do with my vehicles anyway so there are no leaks what so ever, so i would say tube work will probly be needed but dont let that stop you from getting it
Dead2Fall, I recently had the stock "Y" on my 07 replaced with a Magnaflow"Y".The guys at the shop had to cut behind my O2 sensors,then bend pipes to get the new "Y" in.This also pushed the new"Y" further towards the rear.When I went to install my cat-back system I had to shorten the new pipe(from "Y" to muffler).If I had not swapped out the "Y" the cat-back should have bolted right on.I haven't been under an 04 so YMMV.
