Spark Plug Wires
Old Apr 24, 2012 | 04:11 PM
BigRed71's Avatar
BigRed71
Default Spark Plug Wires
Hi Guys,
I have been following the forum for quite some time for info on this, and have come up with inconclusive answers.
Long stock wires vs. ThunderVolt Shorties Taylor #79210.
Some of you say long wires for the after burn plug and some talk about the Shorties and a simultaneous firing of the plug like the 2006 models.
Which is best?
Can someone give me the pro’s and con’s of each, your choice and why?
I own a 2005 QC Ram 1500 Hemi.
Thanks, Big Red
Old Apr 24, 2012 | 09:39 PM
MikeHTally's Avatar
MikeHTally
Most likely the plugs are not fired simultaneously in the later models. More likely the computer fires the plugs in the same order, just the coil-packs fire the plugs when the computer says to.
Some folks have mis-fires when cold using shorties. I used stock-length 8.5mm MSD wires on mine. Shorties make it neater, but I'll stick with the stock configuration.
Old Apr 25, 2012 | 02:18 PM
BigRed71's Avatar
BigRed71
Thank you Mike
