33inch tire question
Old Apr 26, 2012 | 11:21 AM
e1diab1o's Avatar
e1diab1o
Default 33inch tire question
I have a 2003 Ram 1500 5.7L with cranked T-bars and 3.92 gears. I'm looking to upgrade my tires to 33/12.50/17, just trying to get feedback from anyone else currently running this setup. How will this affect my gas mileage, acceleration, speedometer, handling, braking, just any info you all have. I've read that if I go with a 33"+ tire, I should look into 4.56 gears, but I don't have the money for that right now.
Old Apr 26, 2012 | 12:11 PM
Ellis42's Avatar
Ellis42
Here's a thread from another forum
http://www.wranglerforum.com/f5/why-...ars-57812.html
It lets you know about the 4.56 gears and 33inch tires, it sums it up better than I could plus now I don't have to type it all in on my IPhone lol
Old Apr 26, 2012 | 12:38 PM
HammerZ71's Avatar
HammerZ71
Good link BUT, unless you are talking a REAL new Wrangler it's a poor comparison due to the difference in the transmissions. One has to take into account that these newer transmissions have what is basically an "extra" over-drive gear and you can "get away with" running numerically higher gearing and still maintain good highway RPMs, getting "best of both world benefits and all of the low end advantages of the 4.56 and even 4.88 gearing. An '02 or '03 3rd Gen Ram with the 5.9 gasser and the 46re transmission would be turning a LOT higher RPM on the highway given the same gearing and tire diameter as a 3rd Gen with the 545rfe transmission for example.
33x12.5x17s are gonna be ok with 3.92 gears, not the greatest power combo, but not bad either. Now if you had the 3.55s I would have suggested saving your coins rapidly for a gear swap, but you should be fine. If you want more low end then by all means go to 4.56s at some point in the future. Just make sure your wheel choice has less than 5" of backspacing (a negative offset)...
Old Apr 26, 2012 | 02:07 PM
Ellis42's Avatar
Ellis42
I agree hammer, sorry I never really paid much attention to transmission portion of the situation as I said I was at work and on my IPhone so I was just in a hurry
Old Apr 26, 2012 | 03:49 PM
e1diab1o's Avatar
e1diab1o
Alright thanks, I've been looking at another 17" rim with 4.75" backspacing. I actually wouldn't mind dropping down to a 285/70/17, but I really want to try out the General Grabber tire which only comes in 33 or 35/12.50.
Old Apr 26, 2012 | 04:27 PM
HammerZ71's Avatar
HammerZ71
The Grabber is a very good tire, you won't be sorry you bought it...
There is absolutely no reason to apologize for offering to help someone. I was merely adding my point of view to your post...
Old Apr 26, 2012 | 05:39 PM
Ellis42's Avatar
Ellis42
+1 to the grabber tire, my friend has a set I believe and they are nice
Old Apr 27, 2012 | 12:19 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I had 33/12.5/17's on my truck before my current tire. It is the same relative diameter as the stock GY that comes on the 20" wheels, so your speedometer isn't off by much -- if any, at all. The new meat is going to grab and stick better than skinnier, more road-oriented rubber. You will be fine with stock gears and 33's. I didn't notice a HUGE mpg decrease, but, I also hadn't driven my truck in the better part of a year (deployed), and when I got it back it had the tires, new wheels and a 3" BL on it, so I can't really say one thing made a difference over another.
In all, you aren't going to notice a shocking difference, negatively, in my opinion. Go for it!
Old Apr 29, 2012 | 11:49 AM
e1diab1o's Avatar
e1diab1o
Thanks for the feedback guys, really appreciate it. I'm ordering the tires today, can't wait to get em on!
Old Apr 29, 2012 | 08:43 PM
dirtydog's Avatar
dirtydog
Moderate User
My Ram came Stock with 33" rubber(275/60/20) and 3:92 gears. My window sticker stated 13/17.
I wouldnt worry about a thing, not unles you had 3:55 gears, then you'd notice a difference.
