Frame mounted or frame supported Nerfs?
Old May 15, 2012 | 05:48 PM
JerseyHemiRam's Avatar
JerseyHemiRam
Default Frame mounted or frame supported Nerfs?
Hello, great forum and first time poster!
Has anyone found frame mounted tube steps/nerfs for the 3rd Gen Ram? I am now about to replace my 2nd set and the rockers are getting weak and most mounts I have seen mount to the body supports and rockers. Any suggestions? I found these ranch hands but they are a little to utilitarian for my taste. Any suggestions would be greatly appreciated.
04 Ram SLT Hemi - Black
Ram Air induction
Chipped
Borla Exhaust
3rd Steering Pump
Old May 15, 2012 | 09:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hmm....mine are frame mounted and supported. The mount directly to the frame but then have then bars that connect from the frame to them also to keep them from flexing when you step on them
Old May 15, 2012 | 09:41 PM
JerseyHemiRam
I have a set of Nastas right now with two mounting brackets, each bracket mounts to the cab mounts with one support for each mount that attaches to the rocker panels which IMO is a bad design. So what model Westins do you have? I assume each bracket on your Westins mount to the cab mounts, and then and extra support to the frame?
