3" Lift questions.
Old May 31, 2012 | 11:34 PM
bbradUSMC's Avatar
bbradUSMC
Default 3" Lift questions.
http://www.truckaddons.com/Catalog/s...-dodge2wd2.htm
Anyone running this? What all is recommended to go along with this setup. It can't just be bolt on and go can it? What do the spindles do for me and why do I need 4.5 in back spacing in my rear wheel? Won't I need longer control arms as well?
Are there any other lift kits around this price? Would like to do a 3-4in lift.
Old Jun 1, 2012 | 12:49 AM
08HEMI1500's Avatar
08HEMI1500
The spindles or the coil springs would do the same thing height wise but I would see the coils sagging more than the spindles will over time. But yea except for an alignment after you install it its just bolt on and go. And I can tell you from my kit that if you dont have the right backspacing your wheel will hit the front suspension and you wont even be able to make a full rotation of the tire.
