Looked at a 2004 Hemi 2500 4x4
Old Jun 25, 2012 | 11:07 AM
AngelaC's Avatar
AngelaC
Default Looked at a 2004 Hemi 2500 4x4
I looked at a 2004 Hemi 2500 4x4 last night, it drove well, its in good shape for its year, it has 138 000 kms on it which is about 89598 miles, they used it to tow a 30 foot fifth wheel RV. They had to re-do the posi on the rear end so I am going to assume they either burned it out towing or went mud bogging and got stuck or something...As I started it and drove away I noticed a ticking, I have been looking this up and apparently its a common thing? I'm thinking it can be going both ways here either its doing the common thing or it has a problem seeing as they needed to re-do the rear end what could be wrong with the front right? (alot of things) It has been sitting for about a year since the owner of it died and his wife is selling it, I'm obviously going back this week to see it and look it over again, is there something I should look for specifically? Or does it really need to go in and get looked at by a mechanic?
I probably posted this in the wrong topic discussion lol
Old Jun 25, 2012 | 06:30 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Definitely get it inspected by a mechanic (preferably a trusted one) before you buy. Always do that, even if you're buying it from your best friend. You never know what problem may be lurking just a few miles down the road, that maybe even the seller isn't aware of.
Old Jun 25, 2012 | 10:02 PM
04HemiGreg's Avatar
04HemiGreg
Depends on where the ticking is coming from and what it sounds like. Could be the well known hemi-tick or could be something else. If it has limited slip and it has been redone, that could be as simple as it went out due to no fault of the owner. It's a known, potential weak-point on 3rd gens with LSD/Anti-spin differentials.
Never hurts to have a good service history and get it checked by a mechanic.
Old Jun 26, 2012 | 02:48 PM
AngelaC's Avatar
AngelaC
The owner took it in, an exhaust leak said a couple hundred to fix
