tow package??
tow package??
ok so i got a build sheet from dodge about a month ago. it said i have 3:55 gears, but i also have a tranny cooler mounted in front of my radiator. would this be an add on that someone could put on the truck because i thought the tow package had a higher gearing than 3.55's? it also says i have front and rear heavy duty shocks...is that normal on all the 1500 4x4's or is that for the tow package as well? i looked for the trailer connection too and all i have is for the normal light trailers (4 pin) not for like towing campers (7 pin)? connections. thanks guys.
I have the tow package and it comes with the 3/4 ton cooler at least. So if you have less than like 16 rows on the cooler I would say you don't but if your build sheet says you have the tow package then I guess you do lol. I think you can have the tow package with 3.55s, it'll suck to tow I'm sure but you could
Do you see any of these on your build sheet?
XFHPClass IV Receiver Hitch
XFKP7 Pin Wiring Harness
XFUSTrailer Tow w/4-Pin Connector Wiring
NMCPHeavy Duty Engine Cooling
NHBPAuxiliary Transmission Oil Cooler
Or, mainly, this one?
AHCTrailer Tow Group
My guess is you don't have the factory tow package. One of the dead giveaways is the lack of 7-pin wiring connector. Doesn't mean you can't tow anything though.
Trending Topics
I have the trailer towing package and have 3.92 gears, but I also have the 20" tires. I think the shocks are part of the package. I have both the 4 and 7 pin connectors, I also have an electric block heater, and I have never seen another gas truck with this heater. Anyone else have this option on their hemi or 4.7 truck
