Which way to lift truck?
Old Aug 11, 2012 | 08:38 PM
HammerZ71's Avatar
HammerZ71
Longer shocks for sure at 3" of lift and Autozone carries blocks up to 4"...
Old Aug 13, 2012 | 02:41 AM
Brandon Anderson's Avatar
Brandon Anderson
No. I can tell from first hand experience you certainly do NOT need or even want longer shocks if you use just the 3" spindle in the front. The spindle moves the mounting point for the front hub down in order to provide lift. It does not change the distance between the upper shock mount and LCA at all. I used 2" longer shocks on my truck because I planned on installing coil spacers (but never did), and the longer shocks do not absorb the bouncing caused by the coils near as well as they should be. This causes the front of the truck to bounce around like a boat when you hit a bump at speed.
Old Aug 13, 2012 | 11:32 AM
team_realtree's Avatar
team_realtree
Thanks man. That makes sense. I crawled under the truck and looked at all the front suspension and there is no need for longer shocks. The reason I thought the ball joints angles would be screwed is cause I thought just the taller upper ball joint mount was extended but like you say the hub mounting position is the part that is moved. Seems straight forward but we will see...gonna order them soon. Pics to be put up once installed.
Old Aug 14, 2012 | 09:07 PM
PhillyFireLieutenant's Avatar
,,get your chips with dip,, cause ur account will be delinquent. body=looks only.
Old Aug 14, 2012 | 09:43 PM
team_realtree
Huh??
Old Aug 14, 2012 | 09:47 PM
MikeHTally's Avatar
MikeHTally
UP sounds like your best bet.
Old Aug 14, 2012 | 11:46 PM
team_realtree
...ya
Old Aug 19, 2012 | 04:44 PM
team_realtree
Any ideas on how I can extend the front brake lines? Theres maybe enough room for 1" of drop definitely not 3".
Could I just cut the brake line and find a fitting for each cut end and then splice in an additional length of line and hose clamp down the fittings?
Then bleed them..?
Old Aug 19, 2012 | 06:08 PM
HammerZ71's Avatar
HammerZ71
Just buy longer brake lines. My suspension kit came with longer, braided ones but they are available all over the place...
Old Aug 19, 2012 | 09:38 PM
08HEMI1500's Avatar
08HEMI1500
My brake lines just got switched left side to right side and vice versa for my lift
