2500 axle on my 1500?
Old Sep 28, 2012 | 02:25 AM
High_speed_Hemi's Avatar
High_speed_Hemi
Default 2500 axle on my 1500?
Hey gang, i have an 05 hemi with 3.55 gears no locker just a one wheel peel :/. Im looking for more traction with minimum cost can anyone point me in a good direction? Thanks
Old Sep 28, 2012 | 04:34 AM
dirtydog's Avatar
dirtydog
Moderate User
Throw 5 or 6 sandbags over your axle. That's the cheapest solution to more traction beside's keeping your foot out of it!
If you want more traction to be racing and want to get away cheap...Gotta pay to play my friend.
2500 axle isn't gonna fit in a 1500. Anything to do with the differential is not cheap!
Old Sep 28, 2012 | 01:08 PM
08HEMI1500's Avatar
08HEMI1500
Definitely gotta pay to play. The cheapest solution is to just add and LSD to your rear diff (besides Dirty's solution). The best would be to change out your gear ratio unless you like the 3.55s and then add a LSD. Since you're 2WD you won't be paying as much as the 4x4 guys. Maybe tires too especially if you have the stock tires on there
Old Sep 29, 2012 | 04:43 AM
High_speed_Hemi
I have a 4x4 so gears definitely wont be cheap.. i dont mind the 3.55 gears .. can i put a lsd in it without changeing a lot of stuff? Im not to knowledgeable when it comes to diffs and gears..
Old Sep 29, 2012 | 09:38 AM
08HEMI1500's Avatar
08HEMI1500
I didn't think they made 4x4s with 3.55s? Hmm. But yes you can just put in a LSD into the diff but many usually do gears at the same time because 1. shops charge high for labor on diffs so it's cheaper to do both at the same time and 2. It's hard sometimes to find a GOOD shop for our rear ends. You need to try to find someone who has done work on our rear ends before so they don't mess anything up
Old Sep 29, 2012 | 09:45 AM
frederickfrean's Avatar
frederickfrean
Default free seo tools uk
the 3;55 will work just fine on it ,the only difference in the two is you,ll have more power on take off an get better fuel mileage for what your going to be doing with it with 3;92 gears in it,it would hurt you on top end and speed on the free way but hardly enough to notice,good luck.
free seo tools uk
Old Oct 1, 2012 | 05:53 AM
High_speed_Hemi
Ok, i called the dealer with my vin when i picked the truck up and noticed there was no tag on the rearend.. if i do change the gears in the rearend then i will need to do so in the front correct?
Old Oct 1, 2012 | 07:42 AM
08HEMI1500's Avatar
08HEMI1500
Yes you need matching gear ratios in the front and rear diffs
