Anybody know about tires?
Old Oct 21, 2012 | 03:07 PM
OhFive_Daytona's Avatar
OhFive_Daytona
Default Anybody know about tires?
So, I have a 2005 Ram 1500 5.7 Hemi Daytona... I'm going to need new tires soon and I've looked around, I have the 275/60-R20 Rims (The Chrome Clad ones with the large rounded spokes), but I cannot seem to find any "Low Profile" tires for it. It just seems that this particular rim size is JUST for trucks, and I can't get car tires. It's 2WD, so I don't need all that tread, and smaller tires means lower ride height. Thanks if anyone can help me.
Old Oct 21, 2012 | 03:25 PM
sabin420's Avatar
sabin420
Change the tire height and you change the speedometer readout. I take my 2wd offroad a bunch and I have A/T tires. It handles offroad just fine. but then again i'm just driving around in the yard.
Also, the larger tires are made for the extra weight of a truck or suv, which the vehicle weighs twice as much as a car.
Old Oct 21, 2012 | 03:41 PM
OhFive_Daytona
Well I could re-calc the speedo with my Superchips hand tuner, but what confuses me is that my father's 2008 Challenger weighs almost 4,000 lbs and has low-pro's. My truck only weighs about 4,300 lbs so I figured I would be able to get some too.
Old Oct 21, 2012 | 05:14 PM
sabin420's Avatar
sabin420
I would check that again, I know my Quad Cab weighs 7400 lbs. urs should be closer to 6500 lbs if it's only 2 door. You would need to turn your truck into a tube chassis to make that happen. The frame is pretty bulky. Also, I think you may need to change rims to get low profile tires. If I'm thinking right, the bead on truck and SUV tires is a lot larger than those of car tires.
Old Oct 21, 2012 | 05:17 PM
sabin420's Avatar
sabin420
BTW...they do make some pretty good street tires for trucks and SUV's.
Old Oct 21, 2012 | 06:03 PM
OhFive_Daytona
Haha, if you look under my truck there really is nothing besides a gas tank and a muffler. The title says 4k and change on the weight, but it could be wrong. But, I guess the tires don't even have to be really low profile, but maybe just a little less tire than I have no. I just don't know if they make them for my rim, and if they do... What kind of tires do I need?
Old Oct 21, 2012 | 06:57 PM
08HEMI1500's Avatar
08HEMI1500
My truck weights less than 6,000 lbs and that's with a lift kit so idk where this guy is getting 7400 lbs from but with your reg cab you're close to 5k I would say. As for the tires I know you can definitely get low profile tires for our trucks. Look at the lowering kit section in the FAQ and How To area since most of those guys run low pros. You might need to get new wheels but I'm sure they have something for the stock 20s
Old Oct 21, 2012 | 07:15 PM
HemiLonestar's Avatar
HemiLonestar
My quad cab weighs 5300lbs, so I would guess your reg cab is probably around 4800. Chally is designed for down low handling (hence the low profiles). All you have to do is look for different tire sizes. I would stay with a similar width (275) and start looking for lower middle numbers. My stock size for my 03 was 275/55 (slightly lower profile than those godawful 275/60's). The lower that second number is the less percentage of the width it is (which equates to less sidewall). Try a 275/40 and look around there. You may have to vary the width to find what you are looking for.
Old Oct 21, 2012 | 07:52 PM
08HEMI1500's Avatar
08HEMI1500
http://www.tirerack.com/tires/sizes/...sp?diameter=20
Old Oct 21, 2012 | 08:07 PM
sabin420's Avatar
sabin420
OK, just checked the label on the inside of the door...sorry for the wrong numbers but it says GVW 3065kg (06650 lbs) My weight is off the scale at the scrap yard. (I have a bed box loaded to the brim with tools).
