LED floor lights.........
No the brown wire is only live when the dome lights are on. so when the door is open, when you turn it on and when it fades out.
When I checked there was 3.3v on the line when it was "off" and 12.3V when it was on.
You could still use that as a trigger for the relay coil if you wanted lights to be on with the dome lights, but the fading will cause relay chatter for a few seconds. You can solve this with a voltage regulator and a couple resistors.
On the offhand, does anyone what wire I need to tap into the dimming circuit, so that I can power the led's and dim them with the gauges? I think I read somewhere that there's a plug behind the radio/hvac controls that can be used, as well as tapping into the headlight switch. I need a switched power on when the headlight switch is turned on, and also whatever wire is hooked up that dims the lights.
Most radios have a dimmer setting that is defaulted to "off" change it to "dim" or "on" and it should dim when ur lights get turned on, but it wont "dim" when you move the dimmer switch... that's just how most of them work.
There should definitely be an ILLUM wire on the aftermarket radio harness.. they are almost always Orange..
Right. My last vehicle had one, but I don't remember that wire being connected to the factory harness, I know usually there's one that doesn't pin in to the harness. I'll just have to get in there and do some digging I suppose.
Why would it be a bad idea to power them using one of the wires that is controlled by the gauge dimmer switch? I've seen other threads where people have done this as well with gauges, such as autometer gauges and such. I didn't figure that it would put enough load on it to be a big problem. I didn't really want to have to install an additional pot to control the brightness, and I wanted them both to dim at the same time. I was also under the impression all the gauges in the cluster, hvac, and headlight switches were led's based on the led dash conversion how to.
It's not the load that is an issue but the rheostat switch itself works. IDK how it would be in the Dodge but other vehicles I had, those switches gave nothing but problems later when other things were connected to them
