LED floor lights.........
Old Nov 14, 2012 | 10:43 PM
  #41
GRNDPNDR's Avatar
GRNDPNDR
Originally Posted by weedahoe
You guys are taking something very simple and complicating it
yes....yes I do that.
Back to the basics though, I'm just installing those sockets/mounts shown in the picture as my floor lights.
Boom, floor lights done, 2 holes drilled. This was stuff I already had, I just had to remove it from my now defunct car to put into the truck.
So that part is covered......as far as the original topic, my method would really only work for me unless someone heads to the wreckers and pulls those brackets from a couple of 96/97 thunderbirds/cougars, possibly mustangs and crown vics.
I was just toying with the idea of building an electronic relay box to make additional lights easier to give power or functions to.
This is what I do for living, so working with the electronics and building all of this stuff is not a complicated matter for me, its actually dead simple and moreover enjoyable (for me) ..... this is what I do and this is why I'm in the engineering field
I'm just not happy simply wiring up two wires, and adding a couple of easy to install brackets.
Old Nov 16, 2012 | 03:46 PM
  #42
Izero's Avatar
Izero
I just found my old diagrams for the Printed Circuit Board relay centers I made, I've got designs for a 4 and 6 relay center....
I had them quoted out of curiosity, and either of them would cost roughly $150-$175 + Shipping to have made.
They even have slots for fuses, can't believe I still had them laying around.
I might even be able to have them made cheaper with some new knowledge gained since then... I might be doing some tinkering very soon.
Old Nov 16, 2012 | 04:25 PM
  #43
GRNDPNDR's Avatar
GRNDPNDR
Etching the boards??? for $150 you can have all the stuff needed to etch them yourself.
It isn't that hard to do, and you can use magazine paper and your laser printer to print the masks for traces. then you just dissolve in the solvent material.
It's a little harder to do the pretty solder mask and silk screening, but that was included in the $150 cost
$150 seems high just to have some PCB's made though, are they including solder mask, silk screening, drilling, and MULTIPLE boards? or is that the price for just one?
Old Nov 16, 2012 | 04:38 PM
  #44
Izero's Avatar
Izero
Just one board, including all of the components (relays, fuse holders, terminal blocks, etc.
Assembly is still required though, the assembled price is like $300+ from what I remember.
And they use 2-layer printing... I tried doing printing myself once.. never comes out just right and also never seems to last longer than a year or two...
Old Nov 16, 2012 | 05:36 PM
  #45
GRNDPNDR's Avatar
GRNDPNDR
Ahhh, WITH parts. That makes sense now. is 2 layer necessary ? What format is your PCB layout? Eagle, Ultiboard, some others I can't remember right now?
Old Nov 18, 2012 | 08:56 PM
  #46
dirtydog's Avatar
dirtydog
Moderate User
Ya, no doubt. Solution was solved by 10th post!
You guys are crazy. Talking about $300 circuit boards for simple LED installs.....hahahahahahaha
Moved to General because this is waaaaaay off topic and past the point entirely.
Old Nov 19, 2012 | 08:08 AM
  #47
GRNDPNDR's Avatar
GRNDPNDR
WHOA NOW!! I didn't bring up the expensive relay box. I could build the electronic version (basic) for about $20.
Mind you I did just drop $100 @ superbrightleds for all my interior light replacements and a couple of addons
Old Nov 19, 2012 | 08:16 AM
  #48
weedahoe's Avatar
weedahoe
Hall of Fame Member
And you likely wasted 75 percent of your money. Sure they have good stuff. But I haven't seen an LED yet that wasn't made over seas
Old Nov 19, 2012 | 02:51 PM
  #49
Izero's Avatar
Izero
If you go with Single Layer, then you might as well use a bread board....
Also with the 2 Layer you can make a 4 relay board like 3" x 4" instead of 6"x 8" on a single layer, and you don't have to use jumpers....
Old Nov 22, 2012 | 12:03 PM
  #50
SC_Ram's Avatar
SC_Ram
Originally Posted by SC_Ram
Yeah that's what I did.I ran them in line.I just assumed that since the connectors on the switch had 2 silver and 1 gold terminal that the gold was positive so I referred to it as such.I don't know anything about switches obviously so I guessed at it.Any ol' how,I replaced the fuse,cut the switch on again and it didn't cook the fuse this time.I don't know what was different about the 2 fuses but they were both 20's.Just one of those things I guess.
So I was back to square 1 again,as if that's some big suprize .It was been blowin' the fuse again.I finally got it figured out though.I was puttin' the positive wire from the cig lighter on the wrong connector of the switch.I had it on one end but it needed to go in the middle.Any ol' how,I got the lights wired up,got the button wired correctly so I can cut them on and off when I want and all is good now.Thanks ya'll for your help too!
