Need photos before purchase.
Old Jan 3, 2013 | 08:57 PM
dlyter09's Avatar
dlyter09
I am pretty sure that most of the 17's on 1500's except for the plain steel ones are all 17x8... And if I remember correctly the HD's are the same.. I would have to go outside to double check on that.
Edit: Just checked and apparently the HD's are 17x7.5
Old Jan 3, 2013 | 11:29 PM
BIGTEXDODGE's Avatar
BIGTEXDODGE
Originally Posted by 08HEMI1500
I don't think you can put 35s on stock 17s. The stock 17" wheel is 17x7 I believe so its too narrow to take a 35/12.5. I could be wrong though I'm no expert
yea i don't have stock rims mine are 17x9 with +10 off set
Old Jan 4, 2013 | 02:20 PM
dlyter09's Avatar
dlyter09
Most tires want something with a minimum with of 8 inches.. the stock 1500 17 inch rims are 17x8... It shouldnt be a problem running 35's..
Edit: Running a 10 inch wide rim on a 35x12.50 would risk chances of popping beads if you run hard off road.. it can be done but the 8 inch wide rim is what most prefer.
Old Jan 4, 2013 | 03:58 PM
roadkingguy's Avatar
roadkingguy
So..would I be better off with a 315/70/17 instead of a true 35x12.50? I think the 315 is a tad smaller.
Old Jan 4, 2013 | 04:00 PM
Nate_sorenson's Avatar
Nate_sorenson
id go with the 35's , why not if you can fit them. mileage will suffer to a degree but thats to be expected
