Leave the cats?
Old Jan 25, 2013 | 09:49 PM
Old Man with a hemi's Avatar
Old Man with a hemi
I used to have the actual, tested CFM rate of the stock Hemi cats done by a performance shop I was affiliated with at one time, but they went bye-bye along with a LOT of other useful info (like various dyno tests, etc.) when the hard drive on my old laptop took a dump.
So I don't have exact numbers, but they exceeded most all other "stock" cats and weren't that far off from after-market cats sold as "high flow".
Personally, my opinion would be that the difference in flow doesn't justify the cost of getting rid of them for "high flow" cats. Now when they get old and take a sh*t and need replacing anyway, then I'd probably replace them with high flows.
As for the fines for being caught running a vehicle that was manufactured with catalytic converter(s) without them, the Environmental Protection Act allows for an individual to be fined $2500 if caught running without them. It is rare to be fined, but does happen. I personally know someone with a Camaro who was fined for it. More often, the individual is ticketed with a simple "equipment violation".
More commonly, shops get nailed as part of a "STING" on occasion and the fines for a commercial business who removes the cats from an individual's vehicle can be fined up to $25,000 PER OCCURRENCE, which is why it's almost impossible to find a shop willing to do so these days...
Hammer, I'm not disputing what you are saying, but when a person can run cats only and still not have an extremely loud truck, that tells me that the cats are restrictive. I replaced my stock cats with about 27000 miles on the clock, and went with magnaflow spun convertors. The actual convertor is round and 4 inches long with 2, two inch nipples, one on each end, 8 inches total length, and they are about as straight through as any cat could ever be, and I'd guess at least 200-300 percent more efficient than the stockers. I'm sure there are some cats advertised as High Flows that arent that much different from stock, but these are really hi flow efficient cats that are 49 state legal, and may not have been around when your testing was done. The sound increase alone was amazing to me, and my truck runs much better with these than with the stockers. Just my thoughts and opinion
Old Jan 25, 2013 | 10:21 PM
lxman1's Avatar
lxman1
Site Moderator
Noise does not equal flow. At part throttle, my Mustang is louder with a pair of high flow cats than with no cats at all thru Flowmasters and Magnaflow mufflers. (I have both)
Just a note, a gutted out cat is also restrictive due to the turbulence created in the cat body.
I'm not saying that Magnaflow cats don't flow better than the ones on my 08, but not enough to validate the cost to remove good oem's for the minimal gains. Like Hammer, I would install them to replace bad stockers for sure.
Old Jan 25, 2013 | 10:44 PM
Old Man with a hemi
If what you are saying about noise and flow is correct, then what is the reasoning behind replacing stock mufflers with performance brands. As I see it the restriction of the baffles in stock mufflers cancel out unwanted sound waves, but by doing so also adds restriction and less flow to the exhaust, thus less performance and less noise. When going to aftermarket mufflers there is less restrictive area inside the mufflers, therefore more flow, and also more noise. The cats should work the exact same way, so as I see it noise and flow are definately connected...IMO
Old Jan 26, 2013 | 11:28 AM
08HEMI1500's Avatar
08HEMI1500
Well Flowmasters are louder then the stock exhaust yet flow worse then the stock exhaust.
Old Jan 27, 2013 | 04:07 PM
Old Man with a hemi
And you have proof to back up this statement. Flowmaster may not flow as good as a straight thru design muffler, but I'm sure that they flow better than any stock muffler
Old Jan 27, 2013 | 10:27 PM
HammerZ71's Avatar
HammerZ71
He may not, but I actually do have data to represent many mufflers. I put myself through college working at a pretty high end performance shop and have worked with some off/on over the years. As recently as four years ago, I worked at one almost every saturday as a second job for extra cash after my ex nailed me big time in our divorce.
There is a LOT of technology in muffles/exhaust systems today and more than baffling is used to create the desired exhaust note. Some "straight through" mufflers can actually be more restrictive than some baffled or wing plate designs because a lot of the newer baffle systems are created in a way to scavenge exhaust gases faster than just an open chamber.
When I was younger and had muscle cars, the belief was no muffler could flow as freely as a good old glasspack, but the Cherry Bomb Vortex, for example, creates a vortex within the muffler that scavenges gases through it and actually pulls these gases away from the exhaust manifold and thus outperforms even a straight though glasspack and even a straight, muffler-less system.
Dodge Ram OEM
2nd Generation: 285-355 depending on year and engine.
3rd Generation: 365-390 depending on year and engine.
Very Restrictive:
Walker PF29: 217
Thrush CVX: 260
Thrush Boss Turbo: 297
Gibson Superflow: 311
Hooker Super Competition: 320
Summit Turbo: 331
Flowtech Afterburner: 342
Summit Fully Welded: 343
Flowmaster 40: 352
Flowmaster 50: 362
Better Flow (about average for after-market):
Dynomax Super Turbo: 410
Cherry Bomb Pro: 470
Flowmaster 10: 490
Very Good Flow:
Cherry Bomb Extreme: 500
Thrush Magnum Glasspack: 507
Cherry Bomb Glasspack: 510
Edelbrock RPM: 579
Magnaflow 88: 579
Cherry Bomb Vortex: 580
Numbers given represent CFM rates. Some data was collected from various independent tests while other was obtained from the manufacturers.
As you can see, there are some very good sounding, deep, throaty mufflers that are quite restrictive while at the same time some mufflers that offer that type of sound that are very free flowing.
It's my personal belief that the difference lies with companies who choose to spend their $$$ in advertising and there are some who choose to spend it on scientific research and product development...
Old Jan 27, 2013 | 11:29 PM
08HEMI1500's Avatar
08HEMI1500
^^^ That. Hammer has a post in the FAQs where I learned that from.
