Spacers
Ok man you really shoulda looked first haha, theres a gazillion threads about this. Spacers would work for the fitment, but it is very bad for your suspension (puts a lot more wear on the smaller parts). It would be better if you bought new rims that had at least -12mm offset (4.5in backspacing). I've been in the same position as you and this might not make sense at first. I forgot to mention, if you do 35's with spacers your tires WILL rub - not good. Use the searchbar on here and search the words "offset" and "backspacing", you will find a lot more information from those threads. You also might just wana add 33's because with a level, 35's won't look as good all smashed up in the fender well, but that's just my opinion .
*edit
Is your truck a 4x4 or a 2wd? If it's a 2wd I believe that fitment is a tad bit easier
*edit
*edit
*edit
https://dodgeforum.com/forum/3rd-gen...dodge-ram.html
Yes it will work. It will rub though and your truck will ride a lil more rough. check out the link below for every possible spec about fitment.
