Redneck hottub?
Old Feb 28, 2013 | 08:28 PM
eng18ine's Avatar
eng18ine
Default Redneck hottub?
Hey guys. Im gonna be making a redneck hot tub in the bed of my truck this summer, but with all that water, its almost 3000 pounds of water. Do you think this will do damage to a stock suspension? It's a completely stock 04 ram 1500 quad cab short bed. It has a tow package if it matters.
Thanks
Old Feb 28, 2013 | 09:25 PM
08HEMI1500's Avatar
08HEMI1500
Are you sure it's 3000 lbs? I have buddies who I've seen make this and the truck didn't squat too much eve with the water and people in the bed. This was also a Titan
Old Feb 28, 2013 | 09:48 PM
eng18ine's Avatar
eng18ine
when i did the math of how much space was there, it came to around 400 gallons and change. i think 430 gallons or something like that. water weighs somewhere between 7 and 8 pounds a gallon. that comes to 3,220 pounds of water. my truck sits liike a dragster as it is. ill probably be leveled out at that pount.
Old Mar 1, 2013 | 02:42 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
Are you planning on driving around with the water in there?
When I was on Guam in the late 90's, we used to put big sheets of plastic in the bed of a Ford Ranger and fill it up with water. I've seen pictures from those days, and with several people and a floating cooler of beer, the suspension didn't really look a whole lot different. I wouldn't go driving around with that much weight in the bed, though, especially unevenly sloshing around. Looking at balance/handling issues, as well as impact on braking ability.
Old Mar 1, 2013 | 08:57 AM
gcburkett's Avatar
gcburkett
I assume you are not driving it with water in the bed so just place a couple of jack stands under the frame. It will squat enough to put weight on the jack stands and you should not have to worry much. Now in what kind of redneck way are you going to heat the hot tub.
Old Mar 1, 2013 | 12:33 PM
2008dodgeram1500's Avatar
2008dodgeram1500
^^i was wondering the same thing
Old Mar 1, 2013 | 02:25 PM
08HEMI1500's Avatar
08HEMI1500
Obviously with natural gas hahaha.
Old Mar 1, 2013 | 02:53 PM
ewing111's Avatar
ewing111
^^^smh...
Old Mar 2, 2013 | 12:36 AM
wontacceptthis's Avatar
wontacceptthis
I think you should be fine. Isn't your payload like 1600lbs? And that should be what you can safely drive down most roads at reasonable speeds with. A stationary load of 3,000 shouldn't break anything that isn't about to break anyway. Make sure your tires are inflated to handle the load.
Old Mar 2, 2013 | 09:47 AM
rtmtrrdr's Avatar
rtmtrrdr
Then there gonna make it redneck hot tub LOL
