2002 Ram 4x4 1500 3'' rear blocks & 2'' leveling kit on 33's... What next?
Old May 26, 2013 | 10:45 AM
dodgedeerhunter's Avatar
dodgedeerhunter
Default 2002 Ram 4x4 1500 3'' rear blocks & 2'' leveling kit on 33's... What next?
Hey guys, I have a 2002 Ram 1500 4x4 sitting on Nitto 295/70/18 terra grapplers w/flat black vtec raptors along with 3'' blocks in the back. I have ordered a 2' leveling kit, my torsion bars are slightly cranked up so it should be the perfect amount of lift... My Question is do any of you guys have this same or similar setup that you could post pics of? I would like to know your thoughts on this setup, A. is it going to look good, and B. Am I going to need some Bushwhackers to complete the look. I can't afford a suspension kit so this is kind of my cheap way of improving the look of my truck while on a budget!! If you guys have this same or similar setup or know someone who does please post a couple pics so that I can see what it looks like... I'd like to get fender flares at some point, so which affordable set would you recommend for this setup? The tires aren't super wide so I'm not sure which flares to choose. ANY advice on what else I should do would be VERY MUCH appreciated. Thanks in advance for the help fellas can't wait to see some pics!!
Old May 27, 2013 | 11:06 AM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 27, 2013 | 12:52 PM
gHEMImorePower's Avatar
gHEMImorePower
Replace your shocks your truck will thank you. Btw I'm not talking stock you'll need aftermarket ones that are longer
Old May 28, 2013 | 10:56 AM
04HemiGreg's Avatar
04HemiGreg
I'm running 34's on a leveled front only. If you are jacking up the rear 3", I doubt you'll have enough crank to get it level. And with that much lift on either end, you need new, longer shocks.
I put 2" blocks on the back of my chevy and couldn't crank up the front end enough to get it level. I ordered a kit that claimed it would do it but it took all of the spring out of my bars and the truck wasn't driveable without breaking teeth.
Old Jun 2, 2013 | 09:48 AM
boyceh79's Avatar
boyceh79
I have an 04 quad cab. I fabbed my own lift kit. I put a 4" lift on the front and 3" blocks in the back. I added fender flares. Its all sitting on 285/70/17 nitto Terra grappler on flat black vrock wheels. Fabbing brackets to install dual steering stabilizer. I have pics but I'm not sure how to post them. Do I need to upload to photo bucket or something the paste the URL?
Old Jun 2, 2013 | 10:00 AM
boyceh79's Avatar
boyceh79
Old Jun 2, 2013 | 11:00 AM
boyceh79's Avatar
boyceh79
http://i1361.photobucket.com/albums/...ps661c96eb.jpg
There. I figured out pic situation.
