Just wanted to make sure you didn't go buying something that wouldn't fit.
No problem. I've had the Ram for 3 years now an haven't done anything other than the exhaust. Right now, the re-man Hemi is Priority # 1. It will be a step by step process. A re-gear will not happen until other things are done first.
Diablo is a good choice for tuning for your 05 bc you can do custom tune and trans control. Just keep in mind that they have moved on to new tuners beyond the predator so support is waining for it. The 268 is a solid cam as long as your truck isn't too heavy. If it is a 4wd truck you might want to take a look at a cam designed for more low end like a 210x, sidewinder, 216. If you are 2wd then your choices are spot on.
Thanks. I've looked since your posting of this info. I can't really decide on which one to go with yet. A decision might be made by this weekend.
If I can finally decide on one.
"2. Any other items that I should look into up-grading while we're at it ?"
Since you are in the process of "dressing" up the bay then i thought some additional color matching and billet cap pieces may compliment your theme.
Gotcha. Thanks. It's a mess under there. It definitely needs a splash of color.
Valve Covers are done. Went with Translucent Plum Crazy. Not the best looking of pics.
Looking for a SS stud kit for them now. The crap-tastic factory ones are not gonna cut.
