Where to mount a winch on a 2wd
Old Feb 5, 2014 | 10:00 PM
team_realtree's Avatar
team_realtree
Default Where to mount a winch on a 2wd
I've searched quite a bit and can't find any info on this.
I don't want to pay for some fancy pre-made winch mount so I am wondering where I would Weld on a mounting bracket?
I want to have it on the front of my truck. I currently use the factory bumper but that may change at some point.
I would imagine I would have to cut a slot in the middle plastic fascia of the bumper to run the line through?
And then maybe mount it to the front cross member or is that a bad idea?
Old Feb 6, 2014 | 10:07 PM
DirtyDodge812's Avatar
DirtyDodge812
On my truck I took a plate of 1/4" steel with a few holes drilled and bolted it to the two frame rails right at the front of the truck and used that to mount my eyelets that I use for tow hooks. If there is enough room you might be able to do the same thing and mount the winch to that plate.
Old Feb 7, 2014 | 10:58 AM
dirtydog's Avatar
dirtydog
Moderate User
You would need to do more than cut a hole. You would need to mount a fairlead so you don't rub and cut your line. I would recommend a steel backing plate to mount the fairlead to so it doesn't get pull out or bent..etc when you have pressure on it.
There might be a front mount hitch they make for the 1500?? You could put your winch on a hitch mount so this way it will be out away from your bumper and you can removed it easily if needed. i think recessed and hidden is the way to go, but you could have portability with it hitch mounted.
Old Feb 7, 2014 | 11:35 AM
gcburkett's Avatar
gcburkett
The power wagon integrated winch look pretty cool. Maybe you could duplicate that setup on a 1500.
Old Feb 7, 2014 | 04:15 PM
team_realtree
Yes there is a front mount hitch for a 1500. It bolts under the two front frame horns. However its 200$ plus the mount that slots into that is 100$.
I like the idea of bolting a steel plate between the frame horns. Question is if the bumper bows out enough to fit a winch back in there. Will take a look and see.
I thought the fairlead was mounted to the winch lol apparently I need to continue researching.
Old Feb 8, 2014 | 02:42 PM
dirtydog's Avatar
dirtydog
Moderate User
Even if a fairlead is mounted to your winch, you'll want another at your bumper. Anywhere the line will have contact should have a roller. Otherwise, you'll chafe the line and burn up your winch with excess drag.
Old Feb 8, 2014 | 08:38 PM
team_realtree
Makes sense. I came up with an idea- I will post pics when it's done.
Old Feb 10, 2014 | 12:25 PM
DirtyDodge812
I got a couple pics of my plate on the frame rails, the pics are too big for this forum. Ill post em up when I figure out how.
Old Feb 10, 2014 | 12:32 PM
DirtyDodge812
Heres my towbar setup to give you an idea, you might be able to make it work with a few changes.Name:  IMAG0012.jpg
