Difference between 275/60/R20,305/55/20 & 35 12.50-20
Old Dec 22, 2015 | 12:06 PM
Joe.G's Avatar
Joe.G
Default Difference between 275/60/R20,305/55/20 & 35 12.50-20
I have a 04 1500 5.7 4wd Slt Quad Cab and I was wondering what size tire I should get next time around, the truck has New Shocks and bushings not really looking to do a lift kit at this time. For the most part the truck sits kinda level slight rake to the front. Thanks
P.S Leaning toward BFG or Nitto.
Old Dec 22, 2015 | 01:09 PM
Use this to determine the differences between sizes.
https://tiresize.com/calculator/
Old Dec 22, 2015 | 02:06 PM
Joe.G's Avatar
Joe.G
Can i use the 305 on a stock rim with no level kit and no spacers?
Old Dec 22, 2015 | 02:27 PM
What is your stock size?
Old Dec 22, 2015 | 03:34 PM
Joe.G's Avatar
Joe.G
I believe 275/60/R20 is stock size
Old Mar 1, 2016 | 05:09 PM
Joe.G's Avatar
Joe.G
How much difference is there really looks wise and size between the 305/55/20 & 35 12.50-20, They both are about the same price, which would be the better one to go with?
Old Mar 2, 2016 | 10:13 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
What are the load ratings for them? Nitto? If I recall, when I was looking for tires last year, the load ratings were different for those in metric vs. those offered in standard notation. You don't need a HD-rated tire if it's just going to be a daily driver with occasional loading, towing, or wheeling. Those will be a much stiffer ride, and a heavier tire.
Old Mar 2, 2016 | 10:57 AM
Joe.G's Avatar
Joe.G
I am not sure that is something id have to look into. How many ply is a LT tire? More then a non LT tire?
What size/width are the 06 and up 20 Inch rims?
Old Sep 30, 2020 | 04:05 PM
Joe.G's Avatar
Joe.G
Well I know I asked this question a while ago But I finally replaced my tires, I ended up just going with a Stock size 275/60/20. I went with a Toyo Open County AT 3. So far I am very happy with them I have about 5 Miles on them lol. If I was going to change the rims I probably would have gone bigger but for the amount I use this truck I just didn't go that route.
