Spark Plug Wires vs Ignition Coils
Old Aug 5, 2016 | 12:19 PM
dtp220's Avatar
dtp220
Post Spark Plug Wires vs Ignition Coils
I am planning on maintenance tune-up for my truck 2005 Dodge ram 1500 Magnum 3.7L V6 2-door.
I find spark plugs that I want to replace. I am not sure about spark plug wires and ignition coils.
I could not find spark plug wire set (for my truck) at online auto parts. I called a local dealer, they said my truck does not use spark plug wires, it uses ignition coils (I.C.) instead. Does it mean I have to buy 6 I.C.?
Can someone confirm this?
Do I need to buy ignition coil wires, also?
Regards,
Old Aug 5, 2016 | 12:34 PM
Can you open your hood and look to see if you have wires? If you have COP's (coil on plug) you normally don't replace them as a maintenance item. You replace them when they fail..
Old Aug 6, 2016 | 09:23 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
If you're replacing the spark plugs then you should replace the boots as well. The boot consists of a spring which connected the coil to the top of the plug. The boots should be pliable and the springs should be shiny. Pack the boots with di-electric grease (don't skimp) to ensure good current flow. The boots are cheap, so don't be cheap by not replacing them.
Old Aug 6, 2016 | 11:33 PM
dtp220's Avatar
dtp220
I think it is COP. I can easily see 3 on left side. See attached pics.
Do You know how many COP for my truck?
Regards,
Attached Thumbnails Spark Plug Wires vs Ignition Coils-ic-1.jpg   Spark Plug Wires vs Ignition Coils-ic-2.jpg
Old Aug 6, 2016 | 11:36 PM
dtp220's Avatar
dtp220
Thanks for response.
If I replace new Ignition Coils, do I still have to purchase addition boots?
Old Aug 7, 2016 | 09:30 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
You don't need to replace the ignition coils until one throws a code. They're designed for very long life, as in hundreds of thousands of miles.
Old Aug 8, 2016 | 02:02 PM
HemiLonestar's Avatar
HemiLonestar
Only need boots if you rip one taking it out. Make sure you put a little anti-seize on the plug threads when you put them in and a little dielectric grease on the plug itself when you put the coil back in (for future maintenance).
Old Aug 8, 2016 | 06:29 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Boots are cheap and easy, hence why they should be replaced with every spark plug change. Why cheap out and re-use them? The rubber ages due to the extreme engine heat and then the vehicle owner is saddled with trying to remove torn boots at a later date.
Old Aug 11, 2016 | 03:06 PM
dtp220's Avatar
dtp220
Thanks HemiLonestar, Gary-L and jkeaton for your advises.
I talked to a saleperson at an auto part store, he said the I.C. is designed to last as long as its life. Just replace malfunction one as needed, and there are 6 I.C. for my truck.
