oil viscosity causing ticking
Old Apr 15, 2019 | 09:11 PM
jfotsch's Avatar
jfotsch
Default oil viscosity causing ticking
04 Ram Hemi 4wd. Had my oil changed a few weeks ago and they were out of RP 5w-30 and the tech told me all of the hemi's are running 5w-20 (used RP oil and filter) so I did not worry about it then but now it is warming up a little bit and after the engine warms up good it sounds like I have an exhaust leak which I had 5 or 6 years ago so I put a wrench on all of my exhaust manifold studs and they are right where I left them so it is from the thinner oil. A little history; I ran 10w-30(mobil 1) for about 8 years because I live in Las vegas and my owner's manual says to use 10w-30 over 100 degrees fahrenheit so I did. I had just over 100k on the motor and decided to swap to RP-5w-30 a few years back for less strain on seals and it stopped using the Mobil1 oil and the level stayed right at the line at 3k mile service where before it would be 1/2qt. low at same interval with the Mobil 1. Have been performing exceptional maintenance on this truck for 13+ years and it has paid off well. The typical hemi tick has only been occasional and usually when oil needs to be replaced or sometimes when cold.
My question is that it has only begun to warm up here and if it is already making that loud ticking when warmed up good should I swap back out to the 5w-30? My manual does not even mention the 5w-20 so I feel it may be too thin especially with our 115+ degree days. Maybe 40 miles have been put on the RP 5w-20
I do run a slight tune mainly for transmission shift points and tire size and fuel efficiency. Could the timing be making that sound due to spark retardation or advancement in combination with the thinner oil?
The truck was built in 11/03 and runs exceptionally well. I have already ordered the RP5w-30 and I have a couple of the RP filters on hand. Would you change it back to 5w-30 if it were yours? Can I just drain it and leave the filter? Thanks
Old Apr 15, 2019 | 09:27 PM
jfotsch's Avatar
jfotsch
Forgot to ask about spark plugs too! Have maybe 15k on champion coppers. Are people still having good results with NGK 5306 plugs? Bought the set just after last plug change however many years ago that was 4-5 years because of reading good reviews on here about them. Should I gap the NGK 5306 plugs at .40 like the coppers or different due to the mild tune? Thanks again for your time.
Old Apr 15, 2019 | 11:15 PM
00t444e's Avatar
00t444e
I would never use thinner oil than what the manufacturers recommend. Manufacturers always spec the lowest viscosity oil you can get away with, they do that for the best fuel mileage. On many engines it's okay to run higher viscosity oil than the specs but not lower. The ticking you are getting is a typical result of putting in lower viscosity oil than the engine was designed for, especially one with higher mileage.
Old Apr 16, 2019 | 09:13 PM
fj5gtx's Avatar
fj5gtx
I'd run 30 weight, and probably the high mileage version for better additives. Seems smarter to go with the 10w30 if cold temps (below -20 degrees Fahrenheit) in your area are over until the next service.
Here is what the factory service manual shows for 2004:
