Truck not level upper control arm question
Old Aug 9, 2020 | 01:43 PM
Kit Little's Avatar
Kit Little
Default Truck not level upper control arm question
On my 05 Laramie the drivers side sits lower than the passenger side by 1/2". Where the upper control arm attaches to the bracket on the frame it has a slot rather than just a hole. The drivers side which is lower looks like it has slipped back to the back of the slot where the passenger side is in the middle. Should I adjust back out?
Old Aug 9, 2020 | 01:45 PM
I suspect those adjustments are for camber...... Coils or torsion bars?
Old Aug 9, 2020 | 01:46 PM
Kit Little's Avatar
Kit Little
Torsion bar
Old Aug 9, 2020 | 01:53 PM
Just crank the torsion bar on one side or the other to get it back where you want it. Then get a front end alignment.
Old Aug 9, 2020 | 01:58 PM
Kit Little's Avatar
Kit Little
Ok the main reason I noticed it is because I'm having a terrible wandering issue, would that have something to do with it
Old Aug 9, 2020 | 02:00 PM
That's gonna be a tire/wear/alignment issue. Or a combination of all of the above. I would be looking at worn parts first.
Old Aug 9, 2020 | 02:07 PM
Kit Little's Avatar
Kit Little
Ok i just got new tires and they said alignment was good but its hard to find someone that can really align one. Thank you for the information
