Srt10 brakes
Old Dec 18, 2023 | 06:50 AM
Whitetrash04derdge's Avatar
Whitetrash04derdge
Default Srt10 brakes
Hey guys I have a chance to buy 04 - 05 srt10 big brakes from a rollover truck to fit my scsb project I've been working on. Anyone know how much they're worth? Truck had 80 000 kilometers and I'd only need front not rear. If anyone has done the spindle and front swap pictures would be much appreciated 😘
Old Dec 20, 2023 | 11:10 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Nowadays people charge alot for them. They're worthless unless you have the spindles to go with them. FYI 2004 brakes are different from the 2005-06. The SRT calipers won't bolt on to the regular 1500 spindle. If you can get the spindles cheap, it has been proven that the 2004 SRT brakes are just red painted 2500 front calipers and will bolt on & work with the 15" rotor no problem.
https://dodgeforum.com/forum/3rd-gen...y-re-on-3.html
Old Dec 20, 2023 | 01:19 PM
Whitetrash04derdge
ok awesome i have a line on the spindles no matter what. This truck has factory 20s on it just for rollers does that mean they're 04s? Ill ask the seller but do you know everything I will need to bolt these on and will they work with my factory master? Thank you for the information
Old Jan 1, 2024 | 02:08 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Unlike the cars, same master cylinder for regular trucks and SRT's.
The wheels have nothing to do with the calipers. They're both designed to hide within the same wheel. Minimum needed is OEM spec 20x9; not all Ram 20's are 20x9. They cheaped out in later years and had baser model 20x8's.
Old Jan 1, 2024 | 06:55 PM
Whitetrash04derdge
Ok got it thank you
